Old 01-29-2015, 11:14 AM   #1
dirty230
dirty230's Avatar
1 barrel carb choke
The choke cable on my truck would not pull out.The cable was routed through the wrong hole in the firewall and it was kinked. I cleaned and rerouted the cable it pulls freely now.
When i disconnected it from the carb the choke butterfly was tie wired in the opened position.
I cut the tie wire and hooked the choke cable to the carb. Wahla I can now use the choke to warm up the truck in the mornings.
The problem now is when I push the choke in the truck dies.For now I have to leave the choke pulled out a little to keep it running.
1 barrel rochester on a stock 230
Is there a fix for this.
dirty230 is offline   Reply With Quote
Old 01-29-2015, 12:02 PM   #2
Mike Wessinger
Mike Wessinger's Avatar
Re: 1 barrel carb choke
I had a very similar issue on mine late last year. If the choke was not out half or more, it just would not run right. It would die out at stops and just wouldn't seem to want to run very well once it did get going. The problem was solved with adjustment to the timing.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 01-29-2015, 01:43 PM   #3
PGSigns
PGSigns's Avatar
The way it was wired open might of been letting the idle be set by the fast idle cam. May try just turning up the idle screw a bit.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-29-2015, 02:19 PM   #4
dirty230
dirty230's Avatar
Thanks Mike, Jimmy
I'm going to give your ideas a try.
Old 01-29-2015, 03:10 PM   #5
vince1
Napa sells a carb kit for them pretty cheap which come with a new accelerator pump plunger. You could also check that the exhaust manifold flapper thing is working like it should.
vince1 is offline   Reply With Quote
Old 01-30-2015, 11:56 PM   #6
dirty230
dirty230's Avatar
Just a follow up.
The choke is working great. The gas pedal needs to be stepped on to engage and disengage the choke.
Jimmy you were right on. I turned up the idle screw and all is good.
The beast is now idling about 700 rpm.
