Old 01-29-2015, 02:21 PM   #1
adricar1
Larger front brake rotors
I am fitting cpp modular spindles, does anyone know of a large brake rotor that will fit the standard hub assembly. I have a set of large 4 pot calipers from a mustang which is was hoping to find a disc /rotor to use.I have 20 inch rims so i should be ok for clearance, i was just looking for an OE disc which would fit the hub, Any one have any ideas?
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 01-29-2015, 08:26 PM   #2
Mike C
Mike C's Avatar
Re: Larger front brake rotors
CPP sells a big brake kit for your Modular Spindles. That's probably your only option. I see in the UK looks like you were hoping for an auto parts store option, and I don't know of any 13" or larger rotor with 5 on 5 bolt pattern.
You can find something and have the pilot modified as well as the bolt pattern redrilled, but what's it worth to you?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-29-2015, 09:16 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Larger front brake rotors
I have looked and never found anything to use. The stock spindles don't have enough off set to mount anything bigger.
If you are installing the cpp modular spindles you should be good to go with any of these kits.
As stated CCP, McGaughys , Wilwood all have them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-29-2015, 10:38 PM   #4
sprint_9
sprint_9's Avatar
For a stock style replacement with the added flare of slotted and coated rotors I went with Brakeperformance.com I havent used them yet but they seem to be a nice product if you want to stay within the more stock spectrum. The only grip I have is the coating has some imperfections in spots, Im super picky though.
I should note that these are stock rotor dimensions.
sprint_9 is offline   Reply With Quote
Old 01-30-2015, 03:10 AM   #5
adricar1
i was looking at a rear disc on the front from wilwood but unfortunately they are only 12.19 inch diameter. There must be a large rear disc out there ? most of the cpp kits come with the spindles , and i have already bought them . thanks guys i will keep looking.
Old 01-30-2015, 10:06 AM   #6
Andy4639
Old member
Andy4639's Avatar
I'm confused now! What is it you want. These are 13" rotor's.
1st post
Last post:
Call 602-258-0088 w/ Questions
Fits: 2WD 1/2 Ton - 17" + Wheels - 5 x 5
1973 - 1987 Chevy C-10
1973 - 1987 GMC C-10 / C-15
Note:
Front Drop - 2 ½”
Must use 17" or larger wheels
Includes:
2.5" Classic Drop Spindles
Hubs
13" GM SOLID Rotors
Massive GM Calipers
Brackets
Bearings
Seals
Hoses
Dust Caps
Spindle Nuts / Washers
Banjo Bolts
Cotter Pins
Manufactured by: McGaughys in the USA
Old 01-30-2015, 11:39 AM   #7
adricar1
Hi Andy
a rear brake rotor would fit onto the front hub, so thats what i was thinking.
i already have the dropped spindles and the brake kits i have seen do not come without the spindles . unless they are the mega expensive wilwood. i have some brand new 4 pot calipers from a mustang which i could make a bracket to fit the spindle, the problem is finding a rotor (brake disc).
Old 01-30-2015, 11:46 AM   #8
adricar1
Andy i just noticed you have 73 where also the same. when i put that rather than 71 and 72 in to the search engine there are allot more options
Old 01-30-2015, 11:49 AM   #9
Mike C
Mike C's Avatar
I would think CPP would be happy to put together a kit for you without the spindles. Shoot them an email and tell them you already have them and ask about buying the balance of the kit.
Personally, a whole lot of money and not a whole lot of gain for an inch of rotor. YMMV as usual though.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-30-2015, 12:23 PM   #10
Andy4639
Old member
Andy4639's Avatar
These are a little high priced but should work. They are out there you may try a Chevy dealer there and see also. You could use the smaller centers and have them bored out to fit also.
http://www.z1motorsports.com/product...oducts_id=6910
Here is another site.
http://htcracing.com/db1racing.htm
