drivers side sag
I bought a truck in june and the PO had just installed new lowering springs , 2" in the front and 4" out back. I have noticed that it leans a little to the drivers side. I measured it today and it is 3/4" lower on the drivers side front and back. I have also noticed that when I hit a bump in the road that the truck seems to go from side to side a little and also the drivers side from the rear seems to go down more (according to my wife who was riding behind me ). I am not a suspension guru by any means so any suggestion are welcomed. like I said the 2/4 drop is on a 71 short bed with a 402 in it. as far as I know other than the springs everything else is stock. here is a pic and the difference doesn't look that drastic but in person it is more noticeable
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: drivers side sag
normal chevy sag in about close to 100% of old chevy trucks
![]() Join Date: Jan 2011
With a new set of springs it should not have any sag. There was one here a couple of months ago that had the same issue. It was the front springs were not seated correctly and it was sitting up on the spigot that aligns them in the upper spring pocket. He pulled the front apart and correctly aligned the springs top and bottom and it went back to sitting level side to side. Did the truck get new shocks with the spring swap? New shocks and shock relocators in the back made a huge improvement in the way mine drove. Also was an adjustable panhard bar installed in the back.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#4 | |
Update.... No it doesn't have an adjustable pan hard bar or a shock relocator...
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 01-29-2015 at 10:05 PM. |
![]() Join Date: Dec 2010
Look for a thread I started almost a year ago.
Even with new springs, some trucks do still sit lower on the drivers side. I had to add small spring spacers to the front left corner to level it out. I will be converting to bags in front soon and will just run extra air in the same corner to level the truck. Edit.... Here is a link to my thread. http://67-72chevytrucks.com/vboard/s...d.php?t=614923
1970 Shortbed 2wd C-10 |
It may be a good idea to check the other side spring to make sure it's seated properly also check your body and core support mount bushings.
Java Mechanic
There is more stuff on the left than the right. Not surprising it sags over time.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
![]() Join Date: May 2011
If you cant find anything wrong with the way the springs are seated, you may want to swap the springs from side to side and see if the problem continues to be on the passenger side or the drivers side. that way you can rule out if it is the spring or not.
investing in an adjustable panhard bar is almost mandatory when lowering one of these trucks. if you dont have one it can (and most likely is) holding one side of the truck up a little and simultaneously pulling the rear axle to one side of the truck.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
Hope you get this figured out.
MY SUBURBAN has a sag to one side even when its aired out. Original spring had the same problem as well as the drop springs before I bagged it. This is a straight original paint truck never wrecked. just the tolerance they were built to.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Sep 2013
I had the same issue; all new 2 1/2 drop spindles with 3 inch lowering springs in the front and 5 inch lowering spring in the rear. The front driver's side sat a full inch lower. I bought the below .375 coil spring spacer from summit racing (part #sps-1702) an it raised it the one inch i needed.
#12 | ||
#13 |
The super track bar is longer and mounts lower on the suspension, that means that as the suspension travels through its cycle up and down the rear suspension will move side to side less and it will help with lowering the roll center for better bite in the corners. It is the best option. The only down side is that you need to unbolt the rear end from the trailing arms, install the mount on the passenger side and a spacer on the drivers side under the axle pads. It is not difficult, but the shorter adjustable arm is just simply removing 2 bolts and replacing the OE bar with the adjustable one. Both short and long panhard bars are adjusted the same way.
I would go with the Super track bar my self, but my OCD about efficiency out ways my laziness weather I would ever notice it or not.
#14 |
The coil spring spacer was an easy install since all my parts were new. Pop the bottom ball joint off and remove the spring; put the spacer in the lower control arm and re-install anything.
#15 | |
#16 | |
What I can tell you is that in your OP you mentioned that the truck moves from side to side going over a bump and the panhard bar and shocks play a significant roll in that action. The centering and leveling of the rear will almost certainly be corrected with either bar. The question you need to answer for your self is: If the side to side movement bothers you now and how will you feel about buying the short bar and and the wobble over bumps "possibly...possibly" is still there and it "possibly" could have been corrected by the longer bar? Theses are the things that keep me up at night! Knowing there is currently an issue, no matter how small, "I" would set myself up for the highest chance of success and get the long bar. Then I would see if it fits and after running the suspension through its cycle see if I needed to have the tail pipe rerouted, a tail pipe is not that expensive in my opinion. But like I said earlier, my OCD would force me into getting the longer bar even after I bought the shorter bar if the problem continued in any way shape or form. Now, if I got the long bar and the problem continued I could live with the wobble knowing I did everything I could to fix it and move on to a different part to try and fix the problem. Believe me, as I writhe this I know how crazy it sounds, it is just how my brain works. You need to answer a few questions about yourself for yourself so you know how crazy you are about your expectations and decide accordingly. Good luck in finding your crazy level! ![]() ![]()
#17 |
![]() Join Date: Sep 2007
if the truck is lowered more than 4" in the rear a longer trac bar is better. it will keep the rear end centered and youll be happier.
on the same note if the truck is lowered in the rear you shold also get a shock relcator kit for the rear. its cheap and will really make a difference in your ride. you can do the trac bar and the relcators at the same time in about 3 hours. look into early classic parts
1967custom |
