![]() Join Date: Dec 2014
Need help....Motor mounts not lining up???
Here's a couple of pics of what I'm dealing with. I'm trying to mock up my motor but the holes aren't lining up. Ece ls swap mounts going into a 67 that originally had an I6 motor. With these mounts I'm supposed to drill one hole in the cross member. When I line up the one bottom hole the mount sits too high from the top of the frame. I'm completely lost here. Your help is appreciated!
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Need help....Motor mounts not lining up???
Think I would email some these pics and verify all the info with ECE to make sure those are in fact the correct mounts. I would also try fitting them to the motor then lower them with the motor/tranny/drive line (if you have it) to see where your at...Might get lucky and have to drill three holes instead of one...?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
The Older Generation
Those are '73 & up mounts. They are not a direct bolt in. LockDoc
Here is a couple of threads on the subject....
http://67-72chevytrucks.com/vboard/s...d.php?t=128765 http://67-72chevytrucks.com/vboard/s...d.php?t=366800 LockDoc
#6 | |
#7 | |
I have never used them. The only truck I have seen with them in cut a notch out of the frame so the top holes would line up and re-drilled the bottom holes in the cross member to match the mounts. I think he only used one bolt in the bottom. LockDoc .
Ok, that's what I was thinking I would have to do. Thanks for your help.
#9 | |
LockDoc
