1954 frame help...adding power steering
Ok so I'm restoring a 54...I have a powder coated frame with disc brake upgrade on front...has drop straight axle in front and has the under floor style brake booster...I'm wanting to add power steering to it and I will be running an inline 6 with a 2 speed powerglide ....any help on what's out there would be awesome....don't want to change over to a mustang 2 style crossmember want to add to what I have only. ...Thanks in afvanced
Re: 1954 frame help...adding power steering
I've got an early 55 that I converted to disc brakes on the front and went with the steering kit detailed in this article, http://www.classicperform.com/power2.htm
No complaints about the installation or the results afterwards. When I welded the triangular bracket onto my frame I added two trusses on the inside for added strength. |
I have the CPP kit. Love it. easy to install and drives perfect.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
Check out OrrieG's build thread, he used a similar box, not the CPP kit, in his build. Interesting read!
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
