is this right
65 burb. I.might be able to.salvage the passenger side floor. Do I need the rocker pannel backing plate? Or the outer floor sections? I.plan on doing the whole floor. Thanks!
Re: is this right
my outer floor (the long one) came with the rocker back piece. how are your rockers, are you replacing them?
1961 chevy K10 my build is------------61K10 build |
Re: is this right
They're junk
1961 crewcab
Re: is this right
take a look through my sub build in my signature, I have some good shots of the floor and the patching that I needed to do.
drivers side is the same as a truck, but the passenger side: the rocker is the same, the inner rocker piece will work, but there is a step for the passengers to access the back that is not the same as a truck, that part will have to be fabricated if you need it. if you end up getting the floor panel, and rear half panel, you don't need the inner rocker, because it is part of the stamping. you could get the passenger front floor for a truck if you need that piece, but you will have to modify the back part to make the suburban only step.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
