Old 01-30-2015, 02:44 PM   #1
bowcoffin
Muncie SM420
Possibly a dumb question... Will a Muncie SM420 bolt to a small block 350?
bowcoffin is offline   Reply With Quote
Old 01-30-2015, 05:27 PM   #2
kda2000
kda2000's Avatar
Re: Muncie SM420
The simple answer is "Yes" - but look here:
SM420: (4 speed used in ½, 3/4, 1 and 2 ton trucks from 1947 to 1967).
http://www.novak-adapt.com/knowledge/sm420.htm
SM465: (4 speed used in ½, 3/4, 1 and 2 ton trucks from 1968 to 1991)
http://www.novak-adapt.com/knowledge/sm465.htm
The SM420 was the 4-speed for '67, while its replace was the SM465 which was the primary 4 speed used for the 68-72 trucks. The front bearing flange is a different size, so you need the correct bell housing for each, but assuming you have the Chevrolet bell housing for the SM420, it will bolt up to both the V8s and I6s of the 67-72 trucks. The SM420 was made for a lot of years, but only in the last year ('67) does it have a reverse back-up light switch.
kda2000 is offline   Reply With Quote
Old 01-30-2015, 05:58 PM   #3
bowcoffin
Re: Muncie SM420
Thanks! It is out of a 67 C20 so that will solve my back up light problem. Is it a pretty decent trans then?
Old 01-30-2015, 09:58 PM   #4
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: Muncie SM420
They are good if you want durability and authenticity or a granny low.
They aren't so desirable for the street with the long throw shifter and wide ratios. That said, I can't wait to get a gearvendors behind one or a SM465 to split the wide ratios nicely.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
