Old 01-30-2015, 07:12 PM   #1
portworks
eliminating firewall to booster bracket
looking for options to remove the factory brake booster to firewall bracket on 67 to 72 c10.
running into turbo charger interference with the master cylinder !
I thought I read somewhere were someone was using a 63 to 66 pick up booster, is this correct, with no bracket?
portworks is offline   Reply With Quote
Old 01-31-2015, 11:39 AM   #2
dirtyjim
dirtyjim's Avatar
Re: eliminating firewall to booster bracket
I'm running a late astro van booster bolted straight to the firewall. search flush mount booster and you should come up with some pics
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 02-01-2015, 04:59 PM   #3
earl84
Hydroboost will take up a lot less room, and give you amazing braking power.
earl84 is offline   Reply With Quote
Old 02-04-2015, 04:10 PM   #4
bodydropped68
bodydropped68's Avatar
I used a bracket from Captianfab Here is the latest version of the power brake booster adapter bracket that I've been making since 1993. This bracket is fabricated from laser cut 10ga mild steel and fits 1967-'72 Chevy and GMC Pickups, Suburbans and panels and is 100% bolt on using holes already in your firewall. The booster side of the bracket has a 3 3/8" x 3 1/2" hole pattern. Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998. Of course you will have to join the booster pushrod to your stock MC pushrod that attaches to your brake pedal. This can be done by either threading both ends and using a coupling nut, or by just welding them together once you determine the correct length.
I have had the original version ('63-'66) of this bracket on my '66 Suburban and have driven over 120,000 miles with no issues. I have also installed these on a couple of local pickups with good results as well. If you are wanting to add hydroboost to your pickup, Suburban or Panel I also offer a mounting plate for the hydroboost HERE
The price on the bare steel brackets is $55.00 plus a flat $11.65 shipping in the US. If you are located elsewhere contact me for shipping charges. You can also get this bracket in a satin black powder coat for an additional $6.50. Mounting hardware is included. To place an order and for payment information either send me a PM here on the forum or email me at captainfab454@hotmail dot com He is on the forum great guy to deal with
bodydropped68 is offline   Reply With Quote
Old 02-04-2015, 04:24 PM   #5
CHRIS67GMC
CHRIS67GMC's Avatar
Loose the power not needed with proper size master.
CHRIS67GMC is offline   Reply With Quote
