1/2 ton to 3/4 ton running gear
I need advice on choosing the right year of 3 / 4 ton running gear, to put under my '72 short box. I want an easy transition. Plus I am looking to disc brake the rear! Looking to run the new 37's or old school 38's.
I need advice on choosing the right year of 3 / 4 ton running gear, for my '72 short box. I want a relatively easy transition. Plus I am looking to disc brake the rear. I am wanting to run the new 37's or old school 38's.
#3 | ||
"I ain't nobody, dork."
Re: 1/2 ton to 3/4 ton running gear
This a 4x4?
Put a Corporate 14 bolt FF under it. Bomb proof. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#4 | ||
No need to post this in multiple areas...
Gary
Does the year matter? Rumor has it that the '79 is best because of larger bearings?! How about disc'ing the rear, relatively inexpensive?
Hi, welcome to the site. I answered in your other thread.
60-66 Nut
![]() ![]() Join Date: Mar 2007
You can get rear disc caliper brackets from either http://www.Ruffstuffspecialties.com or http://www.Diy4x.com. Reasonably priced and quite simple to do.
You can also retrofit an older axle to discs w/parking brakes using factory parts.
http://s1074.photobucket.com/user/wh...90510598618083 Look into 2000 and newer trucks and 2003 and newer vans. |
Wow! Thanks for the advice!
