Old 01-31-2015, 04:20 AM   #1
dme922
dme922's Avatar
Dbw pedal???
I have a 04 5.3 and i am trying to find out if any dbw pedal and tac module from a 03-06 silverado will work?
dme922 is offline   Reply With Quote
Old 01-31-2015, 01:32 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Dbw pedal???
simple answer, yes. You need the metal-stalk pedal and matching TAC. Late 06 they switched to an all-plastic pedal IIRC.
Best bet is to get one as closely related to your engine as possible. Same year/model etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-02-2015, 10:57 AM   #3
lowlyfec10
Re: Dbw pedal???
pretty much what he said.....tac module needs to match pedal
lowlyfec10 is offline   Reply With Quote
Old 02-04-2015, 09:05 PM   #4
six two swb
Thumbs up Re: Dbw pedal???
hi Dbw i am in the first stage of doing a 04 5.3 got everything for my for swaping into my 62 bbw sb fleetside pedal tac mod running cats under hood fuse box origanal desert factory rad automatic need some info on engine mounts preferable from 04 home fabracated i used a steel tank from a place in that was called chevy duty for my first swap i used a fuel line kit from sur&r it was a snap i have 2 other 60 to66 trucks to do so i got the kp1500 replacement kit has what i need for quick install put in my 66 c10 let it prime a few times busted rite off soon as i can figur out how to download pics only have time to work on my projects is on weekends good luck
six two swb is offline   Reply With Quote
