01-31-2015, 09:46 AM | #1 |
TPI in my 51 GMC
Carburetor went bad again.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
01-31-2015, 09:51 AM | #2 |
Re: TPI in my 51 GMC
I had this TPI I bought years ago at a swap meet. My carb kept screwing up, so I decided to install this. I didn't have a wiring harness or computer, so I went to the U pull it and got that from a 1990 Buick 3.1 V6 and reprogrammed it. I think I have less than 200 dollars in the project, and it seems to run well so far.
01-31-2015, 09:59 AM | #3 |
Nice fix for a carb problem. Looks good!
01-31-2015, 10:09 AM | #4 |
Thanks!
01-31-2015, 10:30 AM | #5 |
Looks great!
01-31-2015, 10:33 AM | #6 |
Thanks, it was a fun project, and it runs much better!
01-31-2015, 11:22 AM | #7 |
Pretty awesome! What heads are you running and what size injectors?
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time '59 Chevy 3100 Stepside |
01-31-2015, 11:51 AM | #8 |
Nice looking set-up...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-31-2015, 11:59 AM | #9 |
The motor is an old 305 truck engine that has been in there for a very long time, so its nothing special. The heads are stock pre-85 truck, whatever that is. I think the TPI is an early IROC or Z28 (85 or 86?) so I did not have to modify the center bolt holes. The injectors are the original 305 type, so they would be 19 lb. It all works well together.
01-31-2015, 04:33 PM | #10 |
Nice install. I have a complete TPI in my attic that I'm waiting to install into the right truck. I have the complete harness from the IROC that it came from, and have already stripped all the stuff I won't need, so it should be pretty straight forward. Probably not as easy as the LS swap that I did to my last truck, but easy enough.
Did you have to reprogram your PROM? If so, who did it? I think I will need a slight tune on mine.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
01-31-2015, 05:26 PM | #11 |
Thanks, I tried to make it look as neat as possible. I don't know anything about LS swaps, but the wiring harness for those looks massive! This one fit through a 1/2 inch grommet in the firewall. I did the programming myself, using a prom burner I got from Moates.net, and Tunerpro to edit the program. Any of the TPI computers are programmable with this stuff, but you have to burn chips and swap them out every time you change anything. That takes some time, but once you get it right, you don't have to mess with it.
02-10-2015, 11:51 AM | #12 |
Are you interested in burning a chip or two for mine when I get to that point?
02-10-2015, 12:04 PM | #13 |
Like your engine, here mine!
---Shawn Cecil-1953 5 window build thread Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189 |
02-10-2015, 02:09 PM | #14 |
That's a possibility, it depends on which ECM you are using.
02-10-2015, 02:11 PM | #15 |
Looks familiar! I used a third gen Camaro throttle cable if you have not worked that out yet.
06-09-2015, 10:13 AM | #16 |
Do you have AC in your truck? If so is your compressor and blower able to compensate for the external heat these TPIs throw out. I truly forgot just how much heat these engines are producing.
My compressor is old but is engaging and holding pressure, cools when you first start up but as the engine runs it just starts blowing hot and cold.
06-09-2015, 11:58 AM | #17 | |
06-09-2015, 01:55 PM | #18 |
Thanks. I am going to have to dig into this a little more.
06-10-2015, 05:47 AM | #19 |
Usually the compressor cycling on and off is a sign of low Freon charge.
My motor home started doing this to me last weekend. Unfortunately, it's an old R-12 system. Gonna have to hit my friend up and see if anybody's still got some stashed.
Old Crow '54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ |
06-10-2015, 07:43 AM | #20 |
TPI is the best truck intake system Chevrolet never put on a truck. Combine it with a low end cam and you've got a real stump puller. Get some 3.08 or 2.73 rear gears with a 700R4 and you'll have a mild little cruiser that can achieve nice economy.
06-10-2015, 09:04 AM | #21 |
I've got carb problems with my 283 in 33 plymouth. It's got vortec heads and roller cam with air. Runs rich even with a 650 holley and stumbles. Gonna do the swap one of these days. Good job on yours.
How to tell when your getting old--- Aunt B starts looking good! |
06-10-2015, 09:25 AM | #22 |
I totally agree with that! I've been very happy with it so far, anytime I want to drive my truck, just turn the key and take off.
06-10-2015, 09:56 AM | #23 |
So when does that TPI setup start running out of breath? I've been told it's around 4500 rpm, is that true?
06-10-2015, 10:49 AM | #24 |
Yes, that's true, 4500 to 5000 is about it. If you want to make power higher than that RPM, they are not the best choice. But a great intake system for a street cruiser.
06-10-2015, 10:36 PM | #25 |
Ok. Is that due to the intake itself or the head design?
