Old 01-31-2015, 04:18 PM   #1
85/Silverado
85/Silverado's Avatar
What Fuel Pump for 350?
The block is a 4 bolt 1978 350.
I need to know what mechanical Fuel Pump I need and if I need the rod to the crank on this engine. I know I need a 6 to 8 psi for the 750 carb.
This came Last Night UPS sure looks nice.
Jack
85/Silverado is offline   Reply With Quote
Old 01-31-2015, 04:25 PM   #2
83swb
Re: What Fuel Pump for 350?
Anything with a 6-8 psi. rating will work, you just have to decide if you want to retain your return system as pumps are offered both ways. This is what I went with:
http://www.summitracing.com/parts/hly-12-327-11
83swb is offline   Reply With Quote
Old 02-02-2015, 10:51 AM   #3
GRADYS Performance
GRADYS Performance's Avatar
You will need the pushrod to go between the cam and fuel pump if you use an engine mounted mechanical pump. You will also need the plate that goes between the pump and the block if you do not currently have it.
GRADYS Performance is offline   Reply With Quote
Old 02-02-2015, 02:14 PM   #4
85/Silverado
Quick Fuel.com said the 750 Slayer Carb needs a 6.5 PSI fuel pump for best results. I was wondering If It would be better converting it over to a Electric Fuel pump (for adjustability) or would It be too much trouble.
Old 02-02-2015, 02:48 PM   #5
MikeB
MikeB's Avatar
I know it's not a performance part, but I've had success with AC/Delco pumps like this: http://www.summitracing.com/parts/ado-40725/overview/ and this: http://www.summitracing.com/parts/ado-40987/overview/
I also had a really nice AC/Delco pump with 1/4" NPT ports that was "clockable" meaning you could rotate it for the best fit. Wish I could find that P/N. Edit: Found it: http://www.summitracing.com/parts/nal-6415325
According to Summit Racing, fuel pressure required for a naturally aspirated 400hp engine = 400 x 0.5 / 6 = 33.3, so this pump's 30 GPH rating would right on the edge at full throttle for any length of time.
The less expensive pumps in the links above have a 5/16" input nipple with inverted flare output. But, hey one of those worked great on a 5,800 RPM 383, but probably wouldn't support that RPM for very long.
Just found this one, and I gotta wonder how much different it could be form the ACs: http://www.summitracing.com/parts/crt-m6624
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-02-2015, 03:37 PM   #6
85/Silverado
Can you tell by this photo what size lines are these? I know that the metal line is the one to the carb.
Old 02-02-2015, 03:40 PM   #7
85/Silverado
I can't find anyone in my remote area that will do a engine swap for under a $1000.00 seams a little high for as clean it is under the Hood.
There Is no smog stuff anymore and the engine was swapped 20,000 miles ago.
Old 02-02-2015, 04:27 PM   #8
GRADYS Performance
If you are paying someone to do the work, have the right tools and hook up all the new parts like your carb with all the proper plumbing that is not a bad price. it is only 20 hours of work at 50.00 dollars an hour. Many shops can charge even more per hour or extra for custom work. Doing it yourself will save you money, and you can put that money towards your tools. As well as learning how to do the job right. As you have posted here you have received a lot of good advice on how to do things the Right way. If you have the time and place to do it you will be much more satisfied when you are done.
Old 02-02-2015, 05:11 PM   #9
aotte1
The following build has info on performance GM fuel pump: "1986 Chevy C10 SWB Step Side". My build and really like this pump for street driven and reliabile: 400 H.P. and 400 Ft-Lbs torque, in a 350 engine.
Fuel pump info, it is a GM high performance unit, I think around 1964 or 1965 was the first year these were used on 365 and 375 H.P. 327 engines. The casting is a little different then the 1965 unit.
"Can be used on all Chevrolet 283-400ci V8 engines. Pump has 7 psi shutoff pressure, 3/8-18 inlet and outlet ports and has a free flow rating of 110 gallons per hour. Technical Notes: 6.5 to 8 psi at 1800 rpm
aotte1 is offline   Reply With Quote
Old 02-02-2015, 05:12 PM   #10
aotte1
Photo of fuel pump, like mentioned above, the inlet and outlet positions on this pump are clock able. Really like this pump, use it on lots of engines, however, did have issue with this particular pump, in that, the pin that connects inside components which makes it pump, was not connected. Easy fix, to take apart, and insert pin where needed to make it pump fuel.
Note: above build also shows the tools I used to make fuel lines, just a little practice on scrap fuel line making bends, and you can do it too. Good tools really make the process much easier!!
Not trying to soap box here, as others here have said many time, rubber fuel lines can be a real fire hazard, I only use metal line, just sharing a little bit of knowledge, to hopefully keep us safe.
Les
Old 02-02-2015, 05:54 PM   #11
85/Silverado
all my lines are on the right side of the pump, and why are there 3?
Old 02-02-2015, 06:15 PM   #12
MikeB
MikeB's Avatar
Line to carb is probably 5/16" tube with flared end.
One of the nipples fits 5/16" hose, but the other looks to be for 3/8" hose. I honestly don't know what the second hose is for. Guess that's because my 82 C10 is the latest year model project vehicle I've owned!
Mike
Old 02-02-2015, 06:24 PM   #13
Jake Wade
Jake Wade's Avatar
Here you go:
http://www.summitracing.com/parts/ado-41216
Jake Wade is offline   Reply With Quote
Old 02-02-2015, 06:35 PM   #14
MikeB
MikeB's Avatar
Here's a link to a 360 degree view of that pump for those who are interested: http://www.summitracing.com/parts/nal-12355612
Click on "360⁰ View" below the pump picture. Those are some big 3/8" NPT ports for use with 3/8" fuel line and hose.
Mike
Old 02-02-2015, 06:46 PM   #15
ray_mcavoy
That looks like the same pump that's on my 77. It has:
3/8" barb for the inlet hose that connects to the 3/8" feed line running along the frame.
1/4" barb for the return hose that connects to the 1/4" return line running along the frame. The return line is used with certain engines to help prevent vapor lock.
5/8"-18 inverted flare connection for 3/8" steel line that goes to the carburetor.
ray_mcavoy is offline   Reply With Quote
Old 02-02-2015, 07:02 PM   #16
MikeB
MikeB's Avatar
Ray -- Thanks for clearing that up.
Mike
Old 02-02-2015, 08:11 PM   #17
enaberif
My hard line is 3/8 OD.
enaberif is offline   Reply With Quote
Old 02-02-2015, 11:42 PM   #18
85/Silverado
Originally Posted by Jake Wade View Post
Thanks That's the fuel pump but I noticed that it is 8 psi constant and that is too much for the 7 max psi I need. That may be the trouble I'm having with my Edelbrock carb that is on my engine now. I always smell gas after I shut down my truck. And there are no leaks.
