Old 08-23-2003, 05:01 PM   #1
formerfordguy
72 GMC SWB
formerfordguy's Avatar
got a ? body swap
Ok here it is i just bought a 72 chevy and a 69 gmc .The question is that the 72 has much rust and body damage but disk breaks and five lug.While the 69 GMC is rust free and dent free but has drums and 6 lug . Would it be easer to swap frount ends or just swap bodys on thease two . I have never done a body swap or a frount end swap . Whaat am i looking at pros and cons either way plz. nether have moter or tranny so will be in the market for those soon this is for my 17 yr old step son. I thank you for you help
formerfordguy is offline   Reply With Quote
Old 08-23-2003, 06:11 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If it was me I would swap front and rear end's the fron cross member simply unbolt's and you replaze it with the disk clip.. As long as the rear are both coil or leaf . Rear axle swapping will be easy if they are both the same.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-23-2003, 06:14 PM   #3
Stroker
I would think swapping the front crossmember and suspension from the 72 to the 69 as an assembly would be the easiest. The crossmember is just bolted in and with the engine out should give you no problem. The brake master cylinder, prop valve, booster and possibly a few brake lines would also need to be swapped. The rear ends are an easy swap if they are both coil rear suspensions.
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 08-23-2003, 08:57 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Agreed.
Although, if you swap bodies, then you candetail the frame pretty nicely. (and here comes the snow ball effect)
Old 08-24-2003, 04:22 AM   #5
formerfordguy
72 GMC SWB
thanks guys i think ill do that we got both trucks for $175 so ive got lots of play room.ill try to get pics soon in the deal i also got the cab and frount clip off another chevy its kind of beat up but has good doors and windshield and asorted other stuff ill get pics soon
Old 08-25-2003, 02:38 PM   #6
nightmare
nightmare's Avatar
well, your talking about the front crossmember and the suspension. what about the rear? the 2 are different also. i would take the body of the 69 GMC and place it on the frame of the 72 Chevy. just my opinion about saving yourself some headache later.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
