Old 01-31-2015, 10:31 PM   #1
Hantke
1966 C20 Minor Wiring (Brake Lights)
So i seem to have this ongoing issue with my rear lights. When i first got the truck the lights would blink really really slowly, now when i turn on the left blinker the right tail light goes out, right blinker and "off" don't have any effect. neither of the front blinkers appear to be getting any power either. The wires were cut and i re-attached them with bullet plugs for simplicities sake, and still appear to have no power. any help would be great appreciated! I intend to look into the switch and see if it has any issues or not.
Hantke is offline   Reply With Quote
Old 02-01-2015, 09:09 AM   #2
Re: 1966 C20 Minor Wiring (Brake Lights)
Sounds like you have the same issue I am working on. Probably bad grounds on the taillights. I am in the process of adding ground wires from the taillights to the frame. I am told this should solve the "weird" stuff that happens.
Old 02-01-2015, 02:30 PM   #3
Hantke
Awesome, thanks! Do I just add a ground to an existing wire then?
2004 Sierra 2500HD - New DD / Work truck
2006 Suzuki GS500 - rebuilt after wreck (summer DD)
1966 Chevy C20 - Winter Project / Future work truck build
http://6066gmcclub.com/forum/showthread.php?t=48548
2008 Lancer GTS - DD / Parts getter - Sold
Old 02-01-2015, 03:53 PM   #4
rickywideglide
rickywideglide's Avatar
i added extra ground wire directly to taillamp housing
rickywideglide is offline   Reply With Quote
Old 02-01-2015, 05:23 PM   #5
That is what I will be doing
Old 02-02-2015, 06:03 PM   #6
Hantke
thanks! i wasnt sure if i should have extended it or how to go about it.
I assume you mean to ground the housing to the body / frame, right?
Old 02-02-2015, 06:09 PM   #7
rickywideglide
i ran wire down to part of bed attached with ring terminal and external tooth washer, i also ran wire to the same piece of bed then to frame.
Old 02-02-2015, 06:52 PM   #8
I am running mine directly to the frame, but what ricky said is good also.
Old 02-02-2015, 11:01 PM   #9
Hantke
Sounds good, thanks!
