Old 08-23-2003, 06:58 PM   #1
darksaga
darksaga's Avatar
front leaf spring bushing?
The bushing for my front drivers side leaf spring (the front one) is shot does anyone know whjere I could get a rubber replacement?
partsamerica.com does not have them
summit does not have the energy (poly ones) in stock
tia
1968 gmc 3/4 4x4 longbed. built 469 700r4 (needs a th400 REAL SOON!), 14bolt ff rear 73 3/4 dana 44
1970 chevelle all wheel disc, tubular rear control arms tall spindle swap up front matching #'s 350 work in Progress
darksaga is offline   Reply With Quote
Old 08-23-2003, 07:48 PM   #2
jabarlow
I got mine at the local 4x4 supply store here in Denver
72 Chevy K10 Short Stepside
72 gmc K2500
jabarlow is offline   Reply With Quote
Old 08-23-2003, 09:46 PM   #3
Class of 69
Class of 69's Avatar
Try this...http://www.offroaddesign.com/catalog/hdshackles.htm under the shackle kit is the spring eye kit.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-23-2003, 10:04 PM   #4
mkmiller1
mkmiller1's Avatar
I just purchased new poly bushing thru O'Reilly Auto Parts. They were $34.00. They won't have them on the computer but they can order them from am "ENERGY SUSPENSION" supplier.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 08-23-2003, 10:53 PM   #5
darksaga
darksaga's Avatar
Unfortianatly for me I have a 68 and those are for 69+
I was hopping that soemone knew the part number for moog or such
I was trying to avoid poly but it may be my only choice, or to bite the bullet and buy new springs (4" lift) but I was waithing to do that untill I could get a longer driveline made (note drivetrain/powertrain not stock to truck)
Old 08-27-2003, 05:06 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Did you check w/ LMC? I believe the 67/68 front springs are the same as 69 and up, it's the rear springs that are different.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-27-2003, 07:23 PM   #7
FrankHoy
FrankHoy's Avatar
This place should have them. I bought some '72 rear shackles from them.http://www.springsnthings.com/chtr4wd12.htm
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
