shock mounting question
So I'm in the midst of doing my front end swap and have a quick question on my shock mount.
Do the upper and lower bolts need to be parallel? Thanks guys, hope to have more pics and info to share soon!
'62 C10 LWB fleet side. 283 w/ a T5 |
Re: shock mounting question
no, bolt direction has no affect on the shock
1985 GMC K2500. 350/TH400/208. 4:10's. stock. 1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD. |
Never Ending Projects
No, no issue BUT I would recommend you put the bolt in the other way before you weld the mount. Right now you would not be able to remove the bolt if you wanted to remove the shock. Put the nut to the inside.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
