Old 02-01-2015, 01:18 PM   #1
324matt
324matt's Avatar
LAB Tested and approved.
Well, here you go. I don't know where I'm going, but this is where I have been. I bought this truck to just have a truck, and, so it goes I decided to do some maintenance. Got carried away. let me know what you think. The truck came with 9x16.5 STA tires, but I went to the local wreckin yard and got a set of stock wheels and tires.
1985 GMC K2500. 350/TH400/208. 4:10's. stock.
1987 Chevy V30. 454/TH400/205 4:10's. Stock SOLD.
324matt is offline   Reply With Quote
Old 02-01-2015, 01:45 PM   #2
324matt
324matt's Avatar
Re: LAB Tested and approved.
Put a 2.5" SkyJacker Soft ride set of springs in the front. ORD Front Shackles with all new Poly Bushings. Piece of cake.
Old 02-01-2015, 01:53 PM   #3
324matt
324matt's Avatar
off with the bed. need to address RUST
Old 02-01-2015, 01:55 PM   #4
324matt
324matt's Avatar
Grinding disks take too long. Sand blast it is.
Old 02-01-2015, 02:02 PM   #5
324matt
324matt's Avatar
new custom 56" springs with ORD 1" add a leaf on bottom and +2" extra arch fabricated into them. St Louis Spring in St Louis MO does great work at Great Prices. New Shackles too.
Old 02-01-2015, 02:09 PM   #6
324matt
324matt's Avatar
got ahead of myself. primed, sanded, primed, sanded, painted sanded painted sanded painted sanded UNDERCOATED the frame. All Rivets that were removed were drilled out to 7/16 and replaced with 1" 7/16 Flange Bolts torqued to 77ft/lbs with red locktite
Old 02-01-2015, 03:11 PM   #7
324matt
324matt's Avatar
So had brand new Monroe sense tracs on the truck. they were too short so I ordered some redi lift rear shock extensions from summit for all 4 corners..
returned them.
ordered Bilstein 5100's from 4wheelparts.
Niiiiiiiice!
Old 02-01-2015, 03:17 PM   #8
324matt
324matt's Avatar
old gas tanks were, um, old. So, Summit for 2 new Spectra Premium fuel tanks (made in Canada) and 2 new sending units.
Old 02-01-2015, 03:27 PM   #9
324matt
324matt's Avatar
the old true dual exhaust was rusty.
ordered some thrush 2.5's for mufflers, and turndowns for in front of the axle.
gonna be loud.
Old 02-01-2015, 03:32 PM   #10
324matt
324matt's Avatar
pile of rusty scrap next to the bed. bed is the next project. sandblast the underside and prime, paint, undercoat.
Old 02-01-2015, 04:08 PM   #11
Jaysonb
Jaysonb's Avatar
Nice work!!
Jaysonb is offline   Reply With Quote
Old 02-01-2015, 07:08 PM   #12
Corts60
Just here to tinker
Corts60's Avatar
Nice! Way to rip into it!
I love those welded thrush mufflers. They have a great classic sound for 1/4 the cost of flow masters.
Old 02-01-2015, 11:17 PM   #13
LSX408
Nice work!
1983 GMC SWB - 350, TH-400
2002 Camaro SS - 408 9sec street car
2000 Trans Am - H/C/I
2014 Chevy Z71
LSX408 is offline   Reply With Quote
Old 02-02-2015, 06:03 AM   #14
brakenit
Active Member
Nice truck, looks like it will be a lot nicer when you're done. I'm looking forward to seeing what the stance looks like once you have it back on the ground. I'm also curious if you'd mind sharing what you paid for the rear springs?
brakenit is offline   Reply With Quote
Old 02-02-2015, 07:30 AM   #15
324matt
324matt's Avatar
I paid $40 for the set of ORD 1" add a leafs, and $365 for the springs made up with the ORD leafs. Plus $60 for U bolts so $465 to put in new 56" springs
Old 02-02-2015, 02:48 PM   #16
brakenit
Active Member
$365 for the springs sounds pretty reasonable. I'll have to keep them in mind if I can't find a local spring shop to make springs for my K30, I'm only a couple hours away.
Old 02-03-2015, 03:27 PM   #17
crashz
crashz's Avatar
Nice truck! And for the rust belt, its in great shape.
Nice to see the care and attention to detail with you maintenance! If you want to maintain my trucks, please do!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 02-03-2015, 03:52 PM   #18
77K10Silverado
77K10Silverado's Avatar
Heck yeah! Keep it up and take a look at my thread. I'm sure well be taking tips from one another! Subscribed!
77K10Silverado is offline   Reply With Quote
Old 02-04-2015, 11:42 AM   #19
324matt
324matt's Avatar
since I work shift work, today and tomorrow is my weekend. I don't like rusty stuff. So I Glass Beaded the drums and painted them, primer too.
ill start using my camera. cell phone pix stink!
Old 02-04-2015, 11:49 AM   #20
324matt
324matt's Avatar
next on my agenda today is to learn how to temporarily fix rust. I will needle gun the rust spots, and then angle grinder sand the metal,
then I will watch about 10 youtube videos and take advise and apply it to this afternoon.
a quick trip to wally world for some bondo and accessories.
stop by napa to get some paint in a can.
post more on this project...
Old 02-24-2015, 09:43 AM   #21
324matt
324matt's Avatar
I got the new tanks installed. and put back on the rock shields. New rubber fuel lines. re installed the heat shields after a blast and paint.
Old 02-24-2015, 09:48 AM   #22
324matt
324matt's Avatar
I also installed new fuel filler neck pipes and rubber tank hoses.
trying to decide on what wheels to use?
Old 02-24-2015, 10:40 AM   #23
brakenit
Active Member
That's a tough decision on the wheels, they would both look pretty good to me but I'm partial to the steel wheels and hub caps.
Old 02-24-2015, 11:56 AM   #24
walkerb
walkerb's Avatar
My vote is for the stockers
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-01-2015, 03:51 PM   #25
77K10Silverado
Yeah I'm a stock guy too. Any updates?
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
