02-01-2015, 09:59 PM | #1 |
Vin or serial number on frame
I just picked up a frame to do a swap. I want to know the year. I want to know if there is away to decode the vin on the frame.? 14072639 on top the below 4 243 (s) 2. Any help would be great thanks.
02-01-2015, 10:53 PM | #2 |
Re: Vin or serial number on frame
The VIN is not on the side of the frame.
It will be on the horizontal surface on the top flange of the frame. That looks like a part number and date code.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-01-2015, 10:54 PM | #3 |
That's not the vin#, you need to look on the top of the right side frame rail between the front two bed bolt holes and where the passenger seat would be for a vin #.
John 82 Chevy Silverado 350ci/TH350 |
02-02-2015, 08:48 PM | #4 |
Also on the drivers side frame rail forward of the engine stands on the top of the rail
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
02-03-2015, 09:01 AM | #5 |
I took a look last night but did not see any other numbers. Will try and take a better look again. Will clear more snow off.
03-15-2015, 11:15 AM | #6 |
Ok found the vin on the frame: CF1126326
Any help decoding would be great.. |
03-15-2015, 03:38 PM | #7 |
Without referring to any reference material, my guess would be:
C = Chevy F = 1985 1 = Oshawa 126326 = sequential portion of VIN K
03-15-2015, 07:26 PM | #8 |
Thank you for the info.
03-15-2015, 07:29 PM | #9 |
Oshawa is where my 1985 was made .
1985 Chevrolet Custom Deluxe 4x2 , 305 v8 , 700R4 transmission |
