Old 08-23-2003, 10:20 PM   #1
70Chevy4x4Nut
How do make your tires even, or do you?
On a 4x4 the rear axle is about 3" narrower then the front. I myself would like to make the tires look even when looking at it down the side. Spacers is one way, but I have heard some do not like them. So is there another way? Or should I just forget it?
Let me know what you have done, if anything to solve that.
And what kind of problems would I run into with the spacers?
70Chevy4x4Nut is offline   Reply With Quote
Old 08-23-2003, 11:41 PM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
I would never use spacers. They put too much strain on the lug bolts. If you are really worried about it, I would find wheels with wider offsets for the back. I have about 16 differnt wheels and I know the offsets are different enough among my wheels that I could pair uo a set to handle 3 inches.
Personally, I don't worry about it.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 08-24-2003, 12:08 AM   #3
70Chevy4x4Nut
It's not so much worry, as I think it looks better. I could live with it if I had to. I had also thought of correcting it with wheel offset, and that may be a real good way of doing it. The drawback is not easy to rotate tires. I guess I really wanted some opinions from those that have done it, how they did it, and how it's working out.
Old 08-24-2003, 07:50 AM   #4
85 K5
I've heard some vans have wider rear axles. You could update to 14 bolt full floater. I run 1.5" spacers but for the first 4-500 miles I pulled the wheels and checked torque on all bolts at least every 100 miles. I would think this puts extra stress on axle bearings but I've read others have used them for years without any problems.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock
http://www.oplnk.net/~spirit/K5front.jpg
85 K5 is offline   Reply With Quote
Old 08-24-2003, 02:02 PM   #5
CRRoy71
I run the 1.5" billet spacers on mine.
I haven't had any problems for over a year now.
(Knocking on wood)
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 08-24-2003, 06:09 PM   #6
70Chevy4x4Nut
Hey 85 K5, what year vans would I be looking at? And will they be 5 bolt pattern, cause I have 6 bolt now. Would like to leave them 6 bolt if possible. If the van axles don't work, then the spacers seem to be the way to go.
Old 08-24-2003, 10:27 PM   #7
MJN
MJN's Avatar
They made trucks like that so that they would track better and it improves off roading too, got something to do with the front end and steering.
Old 08-24-2003, 11:09 PM   #8
70Chevy4x4Nut
Does it actually track better? Do the new 4x4's have this design? I don't think they do. I wonder when that all changed.
Old 08-24-2003, 11:45 PM   #9
1969 GMC
1969 GMC's Avatar
if you have 6 lug, then you can't get a 14 bolt FF, they are 8 bolt.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-27-2003, 06:35 PM   #10
MJN
MJN's Avatar
Our '94 S-15 Jimmy has the rears set in and the fronts stick out, might just be a 4x4 thing. I've seen the newer trucks with the frontend wider than the rear.
Old 08-27-2003, 09:04 PM   #11
70Chevy4x4Nut
I guess I have'nt really taken a good look at the newer trucks. I will look closer. Maybe even take a measurement. Thanks
Old 08-29-2003, 09:57 AM   #12
1FaastC10
1FaastC10's Avatar
custom axles man... you could have 4lug if you wanted to
1FaastC10 is offline   Reply With Quote
