02-02-2015, 11:01 AM | #1 |
Fuel tank behind the seat?
Keep it or loose and why?
Thanks! BTW it's on the road now and running strong.
1970 C20 350/TH350, LB God Bless our Troops |
02-02-2015, 11:50 AM | #2 |
Re: Fuel tank behind the seat?
I'm debating this very thing myself right now. I don't really have a problem with the gas tank behind the seat but I do smell gas sometimes. I have a new seal that goes around the filler neck to install but haven't gotten around to it yet. I'm hoping that will solve the gas smell I get occasionally, but it only happens after filling up and taking hard right turns.
My reasons for wanting to possibly move the tank to under the bed are as follows : 1) Safety (worried if I get smacked hard enough or flip the truck it could be a big problem) 2) gas smell 3) would free up room behind the seat for speakers I would need to figure out how to rig something to make it look like I still have the cab mounted tank. By that I mean if I remove the tank behind the seat, it would leave a hole in the cab where the tank filler sticks out. Your options there are to either fill the hole in and repaint, or I've seen people cut the filler neck off and rig it so its still there but there isn't a tank there. So from the outside it looks normal. Also as for putting the tank under the bed, you either have the filler coming up through the wood or metal bed near the tailgate, or through the side of the bed.....i've also heard of people rigging something where the filler is behind the side marker in the rear and it flips open and is spring loaded. I saw recently too someone used a late 1960's camaro tank and the filler was behind a flip down license plate. Many options and potential hurdles to overcome when doing this change. Hope this gives you some ideas and helps you begin to make a decision! Good luck!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
02-02-2015, 11:56 AM | #3 |
I wouldn't waste my time.
Reasons: It's a waste of time and money. I'm not worried about safety. (Not that there's a real concern anyway) There's nothing I'd like to put behind the seat in its place. I think it's neat back there. |
02-02-2015, 11:59 AM | #4 |
Keepin an eye out
Im ditching the in cab for an under the bed aluminium with built in fuel pump to feed the 5.3
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
02-02-2015, 12:58 PM | #5 |
well since you already have a Aux fuel door from the factory, I would relocate to that spot,
but I am a tall guy who likes a little more leg room and speakers behind the seat
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-02-2015, 01:24 PM | #6 |
Welcome!!!!! As for your fuel tank debate.... we go over that every couple months here on the board, i'll try to break it down into legitimate arguments and not hearsay
Exploding gas tank: When is the last time you heard of one of these exploding? Further, when's the last time gas in the cab of a truck regardless of being in a tank, cup, or fuel can has caught on fire from an accident? Then, when's the last time someone has walked away from a wreck in this style truck where the impact was strong enough to cause a leak in the tank? The answer is never been documented, never been documented, and never been documented. Fuel smell in the cab: Proper fuel sender gasket, fuel vapor hose, and fuel cap solve these issues. Not only should it be done for the gas smell, but for a good functioning fuel system as well. I'd love my rubber to last 45 years but unfortunately they deteriorate and need replacing. Fortunately it'd cost under 30 bucks for all of them. Extra room in the cab: Now this is legitimate, as long as you aren't talking about seat room, because they hit the back of the cab before you need the space the fuel tank is taking up. That is a significant amount of room to be used and moving the tank for that reason is justifiable over the other myths. Lets not even get into the Pinto debate which has already been debunked and overdramatized. If you have an OCD issue about riding with fuel, that could also be justifiable. You are much more likely to get into an accident with a fuel tanker or run into a propane tank and have that explode than you are the fuel tank in the cab. Also, little compact cars like to get wedged up underneath the back of trucks, which would put your proposed fuel tank directly over a hot, mangled mess. Food for thought |
02-02-2015, 01:45 PM | #7 | |
Good points man! I'm most likely leaving my tank where it sits... Not on my short list of things to do thats for sure!
02-02-2015, 03:58 PM | #8 |
C10 Collector
I'm keeping mine on my 67. Its part of the Nostalgia.
In my 72 I moved to the rear for weight distribution and to shave the filler. In my 67 I tig'd a -6 fitting into the side of it for the return hose from the LS swap. My spare is under the bed. People will come up with all kind of reasons why they had/wanted/needed to move it or not. Its likely not a safety hazard but there are many reasons to move it or not. It comes down to personal preference.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
02-02-2015, 04:52 PM | #9 |
I am keeping mine as is ... as it was manufactured.
Hey ... you asked
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-02-2015, 05:00 PM | #10 |
Thanks for all the input I'm keeping the tank in place. What's the best way to clean it out? The fill tube looks nasty may because the locking gas cap is loose and sat for 14 years in field. LMC for parts?
02-02-2015, 05:27 PM | #11 |
C10 Collector
I have a tank but you're kind of far. I got a used original 68 tank from a friend that still says US Steel on it. They are easy to find to with everyone going to rear mount.
02-02-2015, 05:45 PM | #12 | ||
"I ain't nobody, dork."
I'm moving mine. But not because it's unsafe and all that malarkey... I want more weight over the rear axle and not amidships.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
02-02-2015, 05:55 PM | #13 |
Movin mine. Efi pump, weight over the wheels, free cab space, no gas smell and I'm shaving the filler neck.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
02-02-2015, 06:47 PM | #14 |
Cruzin
Leaving mine would rather have the spare back there. I love the look of the filler neck in the cab. If I did move it I would leave the filler don't like the shaved look anymore.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
02-02-2015, 07:16 PM | #15 |
I'm looking for a stock tank to put behind the seat of my 68. So if yall know anyone who has done the conversion and is getting rid of the stock tank let me know! Thanks.
02-02-2015, 07:31 PM | #16 |
Welcome! Good to see another Utahn. I will hopefully move mine under the bed somewhere, but I'm leaning toward a Duramax swap, and diesel smells like hell...
Justin '67 C20 CST Custom Camper '04.5 LLY Duramax CCSB...sold |
05-19-2018, 06:51 AM | #17 |
Im thinking of moving it back into the cab for originality.
05-19-2018, 08:15 AM | #18 |
I went back and forth for a long time over this conundrum. I was going to move it because after getting my truck out of a five year storage (while I was stationed in Germany), I had a lot of rust and sediment in the bottom of my factory tank. I even went so far as fabbing the filler door/tube and collecting most of the hardware to move it. I even had the tank kit in my "shopping cart" ready to place my order. But in the end, I figured out how to fit the soud system In/under the seats, I couldn't bring myself to cut into my pristine bed side to put the filler door in.
Of course this is my choice, and should I find another truck to build later, I'll do the under bed tank. (I'm already collecting parts for a truck I don't have) |
05-19-2018, 09:25 AM | #19 |
I don't really like filler doors either, or cutting holes in the bed wood for a filler. Slightly more appealing and subtle, but less original looking than the flimsy metal dealer saddle tank doors, is a grafted in more current filler door - but if your paint is already done, that's not a good option. There are wheelwell fill necks that are almost invisible inside the wheelwell/bedside if you can find them.
Me, I'm keeping my cab tank (along with the two saddle tanks) so I can pass up one more gas station. Below is a pic of a nicely done later model fuel filler door grafting - saw this truck at Brothers Truck Show a few years back parked next to the orange and black Overhaullin truck. |
05-20-2018, 06:21 PM | #20 |
Iam thinking of moving it back. I have a tank that mounts in the rear with the spout that comes out between the rear tailgate and the bumper.
05-20-2018, 06:49 PM | #21 |
Leaving mine.
68 K20 Custom Camper/CST Wrecker. 97 GMC K1500 short bed reg cab. |
05-27-2018, 10:05 PM | #22 |
took my tank out of the bed and getting ready to install back in the cab. I have the tank for sale with a hitch as well.
05-27-2018, 11:52 PM | #23 |
For all you youngsters, do you remember the Ford Pinto? Where was the gas tank located? Under the car in front of the rear bumper.
Mine's staying in the cab. https://www.youtube.com/watch?v=lgOxWPGsJNY
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
05-28-2018, 10:27 AM | #24 |
If you smell gasoline, you have a bad fuel sender o-ring or hose somewhere, that needs to be fixed. A fuel leak is not a good idea regardless of where the tank is located.
05-28-2018, 11:21 AM | #25 |
Leaving mine in the cab. Planning on carrying a spare in the back.
1968 SWB Step Side, Big Block, 4L80E , Running! |
