Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-02-2015, 04:58 PM   #1
jumpsoffrock
Clutch sizes for '67 C50 w/ 327 & 4-spd?
Anybody know how to find out what size clutch I have? NAPA has nothin on record, and a local parts house says they need to see mine to compare to. Any ideas on what might tell me? Both shop manuals I have don't say anything about specifics.
Thank you very much.
jumpsoffrock is offline   Reply With Quote
Old 02-02-2015, 06:26 PM   #2
mrolds88
Re: Clutch sizes for '67 C50 w/ 327 & 4-spd?
From my experience, you SHOULD have a 13" clutch. To make sure, look at the bellhousing. The 12" and smaller just had a cast bellhousing that bolted directly to the block. The 13" clutches have an adapter plate that is about 1/4" thick. And the bellhousing is rounder than the smaller clutch bells.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-02-2015, 08:06 PM   #3
jumpsoffrock
Although there is quite a bit of gunk in the way, it doesn't look like there is a plate, but I'll do better looking later on.
Any clue who might carry them if I did have the 13"?
Old 02-03-2015, 12:01 AM   #4
mrolds88
Any MD/HD truck place should be able to help. This one on ebay should fit the bill too http://www.ebay.com/itm/Chevrolet-Me...854c7f&vxp=mtr Also the 13" and larger has 4 fingers and the smaller ones have 3. Also that plate has one bolt that bolts into the block on one of the starter mounting holes. (passenger side, bolt holes are vertical).
93 K2500 xcab 6.5TD
Old 02-04-2015, 02:38 AM   #5
jumpsoffrock
Awesome, Thank you very much. Big help.
Old 02-08-2015, 02:20 AM   #6
jumpsoffrock
I just had the bright idea to look from the top of the engine, and it looks like there is a plate in between, so I'm gonna think I have a 13" clutch. but won't order it 'till I get it out to measure. Not worth the mistake.
Thanks for the help again. Always have good info.
