02-02-2015, 06:56 PM | #1 |
Help removing I6 250/3 Spd
Need a little help identifying some "need-to" areas for pulling my engine/trans in my '66. This is my first time tackling this, so can somebody give me some pointers on what I need to remove?
The truck is the typical I6 250 and 3 speed column shift, I've already got the (4) bolts for the motor, but I'm trying to find the bolts to remove for the engine, the area's hidden under a bunch of grease. Also, what else am I going to have to remove in order to pull the motor/trans? Can anybody help me out?? |
02-02-2015, 08:04 PM | #2 | |
Re: Help removing I6 250/3 Spd
02-02-2015, 08:09 PM | #3 | |
02-02-2015, 10:56 PM | #4 |
I should clarify some, I have a 350/350 that I want to swap in. I have the engine perches & engine pads and also the tubular trans mount and pad from CPP. I just want to remove the old running gear and install the 350 items.
02-04-2015, 04:24 PM | #5 | |
02-04-2015, 04:52 PM | #6 |
Step by step good luck finding tool J-4536-A though
02-04-2015, 05:50 PM | #7 |
