![]() Join Date: Feb 2007
decode this motor
Can anyone decode this I've tried to Google how to but no luck really
It's a small block numbers on the back drivers side are 3970010 on the front passenger side v1029chh 18j164214 |
Re: decode this motor
The CHH suffix with that casting# denotes a '78 350 auto trans LM1 170hp 4bbl full size car engine VIN L. The V prefix is the plant, which is Flint engine plant. The 010 casting is what I like. You can build a hi-performance motor with better cam, heads, etc. For instance, a '70 Vette with 300hp 350 uses that same block
K's right. Probably out of a smogged up impala or Caprice or the like, but has ability to be a damn good block.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
![]() Join Date: Oct 2014
I also have tried to look up my engine. I haven't read the casting numbers on the back, but the front reads VO116HN. Does that mean anything or do you need the back numbers.....
I have looked in my LMC catalog and Googled the number, but I am not finding anything.... |
![]() Join Date: Nov 2001
The 18j164214 is related to the VIN of the original vehicle.
The 1 is the 1st digit of the vin, and means Chevrolet The 8 is the 6th digit of the vin, and means 1978 the J is the 7th digit of the vin, and means Janesville assembly plant. 164214 is the 8th through 13th digits of the vin, and is the sequence number. Thanks to bruceman1968 for the knowledge on this subject.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 02-03-2015 at 04:04 PM. |
#6 | |
You'll need the cast number to narrow it down. http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php And another good link, http://www.mortec.com/ |
So by that number with the suffix HN I can tell it is from a 69 "full size". Is that correct? Hmmmm....I wonder why someone would drop a 69 engine into a 72 truck!?!
Is there a way to see the casting numbers on the back of the motor without pulling the engine? I know it says it is hard with the engine in, but any tricks? |
I got a trick or two!!
Mirror. Use the wifes. Don't tell her!! LOL!! Flashlight. Angle the mirror back there. Point the flashlight at the mirror. Ta Da!! Can't miss it. |
![]() Join Date: Dec 2012
Stuff your phone down there and take a pic. Use the voice activation and hold still.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#10 | |||
"I ain't nobody, dork."
All the 350's in these trucks were pretty much the same animal. So I wouldn't get hung up on what year engine is in what year truck. Unless you're going for a 10 point restoration... it's just a power plant to make the truck move. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#11 | |
For some reason that is a classic quote right there.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#12 | |
Thanks for the input! It is supposed to be a rebuild with about 24K since rebuild. It is in a 72 Cheyenne Super. I post pics soon. I couldn't hang with old green. Needed too much welding and I cant do it!!! |
