Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 08-23-2003, 11:55 PM   #1
gmtrucksaddict
sellinga reliable 53 chevy 6400 2 ton dumptruck
selling 53 chevy 6400 chevy 12foot dump truck, is now flat bed after removingallthe oak grain bed side panels, only rust is someon floorboard, about tennis ball size hole in it, and alittle bit missingoff very bottomedgeof fenders, rockers and such areclean, ceptminor onone rear cab cornerupunderneath,. doors solid and allglass good and 6volt system and guages operational, 235 six withnot even apuffof smoke at startup, 4 speed trans with 2speed eaton rear, but axle doesnt go into hi range for some reason, i dontknow howit works,its vacuum operated i know.
is listed in peoria IL trading post for 1000 or trade for a '76-78 dead or alive nova 2 door or a decent GM pickup 1/2 ton through 1 ton '67-87, bed and hoist is twin dual stage and works perfectly, no leaks or anything, and you can hear it all runover the phone if you want
7800is what it weights empty and fullyloaded combined weight is 16,000 in which is max you can drive on normal drivers license in IL,
its huge truck,would be best as restoration or parade use or on-farm use only,wipers are not connected under dash and rad capneeds replaced from NAPA and parking brake drum linkage needs adjusted at the tranny tail,
it is dark green painted, headliner and everything intact cept upper door panels,dome lamp works too. locks all work, starter foot switch is still on floor next to gas pedal,rear wheel studs and nuts are brand new,oil pump and pan gasket are brand new too
thanks for looking
gmtrucksaddict is offline   Reply With Quote
