Old 02-03-2015, 12:47 AM   #1
Henney
AD Truck LS Intake
Just curious what people have been doing for their air intakes on LS swaps into AD trucks. Pictures would be great. Thanks.
Henney is offline   Reply With Quote
Old 02-03-2015, 01:40 AM   #2
snehpetsffej
Re: AD Truck LS Intake
I'm doing a holley ls hi ram. I'm located in Albany OR. maybe we can trade info.
snehpetsffej is offline   Reply With Quote
Old 02-04-2015, 11:23 AM   #3
Henney
What are you plumbing from the manifold to the filter/MAF? And where are you planning to have your filter? I think that's the part I'm struggling to see because there isn’t a whole lot of room up front for a filter and it doesn’t seem like anywhere will get good clean air. The photo below I pulled off of the forum somewhere and now I can’t find the thread but it seems like the filter location would be getting lots of hot air.
Old 02-04-2015, 05:22 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I"m guessing if he's running a Hi-Ram, the clearance issue won't be the same. That manifold sits like 4" taller than a standard one, and has an angle built into the tb mount.
As for your intake situation, I might suggest looking at something called a Cobra Head elbow. It goes by a few names, but its basically a 90* elbow that ovals out to keep the same flow in a tighter bend. Its very similar to what used to come on the intake paths of vortech blowers.
Looks like this
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-04-2015, 07:33 PM   #5
Angryman117
I am planning on running an afe cold air intake that I picked up from a salvage yard for cheap. The plan is so far to run it through the inner passenger fender and box it off then make an opening behind the grill so I have cold and ram air. Unless anyone else has a better idea please let me know. Most of this stuff I am figuring out as I go. I can try to add more pictures but phone will only let me do one for now.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 02-05-2015, 12:31 PM   #6
solidaxel
solidaxel's Avatar
That was the first option for us also, keep us posted with the air box.
That should be a great location for "cold air"
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-06-2015, 04:28 PM   #7
BigRed76
BigRed76's Avatar
Just a thought...how much space do you have behind the intake manifold? I've seen some swaps where people flipped the intake around so that the TB was at the back of the engine, but they were different applications than an AD truck
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-06-2015, 05:16 PM   #8
Henney
I don't have any room. There's maybe 2" between the back of the engine and the firewall. I think there's enough room to get it routed out of the front but just not sure where the best air is. I'm thinking the inner fender air box idea is best so far.
Old 02-06-2015, 05:37 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You'll see it in boats and buggies which run the tube into the cab, or on ultra high HP cars which use A2W from the cabin.
OP, you can always switch to running a 4150 style manifold/TB combination. You won't have to worry about front clearances (and you'll go SD in the process).
Old 02-08-2015, 09:58 PM   #10
Iceburgh
Iceburgh's Avatar
check out my build...... I cut a whole in the inner fender and routed through the front air dam for cold air
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 02-09-2015, 12:24 PM   #11
torchlight
torchlight's Avatar
Yup!
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 02-09-2015, 12:28 PM   #12
Matt Cramer
Currently running a throttle body mounted Spectre filter, but I'm planning to section a K&N intake tube to get the filter in a better location.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-09-2015, 04:54 PM   #13
Iceburgh
Iceburgh's Avatar
1953 suburban build
