C10 Suspension Lift
My springs are pretty much shot on my C10 so they need replaced. I like the look of the truck sitting up a bit higher.
What options are out there to lift my truck 2 - 3"? Are there taller coil replacements out there? I don't want to compromise the suspension or steering geometry angles. Nor do I want to stiffen the ride feel. Hoping for a new set of taller coils and extended shocks. Thanks in advance!
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
![]() Join Date: Apr 2008
Re: C10 Suspension Lift
New springs would lift it some. In an old Ford I had I put big block springs in mine to get some tire clearance. Not sure if that would work here maybe someone else will chime in.
Ttt would like to know about this also.
Here is an old thread that has some links as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=563288 Taller ride height springs need to be stiffer to have a similar free height than stock. Even stock replacements are probably going seem harsher.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Found a place that makes custom height springs to factory ratings, I believe its coilsprings.com.
I received a quote for +2" springs for $200 a pair. My question is would I have to change out any other suspension component (shocks, tie rods, etc) or make any modifications to get these springs installed? I would imagine it would be difficult due to the additional 2" of compression to install. TIA!
#6 | |
Still looking into this.
Would I have to modify anything going 2" higher springs? For example, would I have to replace the driveshaft, radiator mod to accomodate higher stance, other suspension components that need to be replaced to accomodate higher stance? Thanks in advance!
