Old 02-03-2015, 01:07 PM   #1
88CopperTop
Porterbuilt dropmember motor mount not lining up.
So we have a 56 in the shop we're putting together. Full porterbuilt front airbag setup. The motor mount location on the sub frame isn't lining up with the motor mount location on the dropmember. Its about a 1/4" off on the passenger side and a little more than that on the drivers side. Is this just welded wrong or am i miss something here? The whole front end is bolted together, with brakes and tires mounted also, so i dont have any room for adjustments.
88CopperTop is offline   Reply With Quote
Old 02-03-2015, 01:20 PM   #2
88CopperTop
Re: Porterbuilt dropmember motor mount not lining up.
Just realized i posted to the wrong location.... I got an email from pb also. Can we delete this?
Old 02-16-2015, 06:35 PM   #3
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Mine is off by 1/4in on the driver side.
ChuckDriver is offline   Reply With Quote
Old 02-16-2015, 06:38 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Can you tell us if you got your problem solved?
Keith
Convert to disc brakes.
Old 02-16-2015, 08:05 PM   #5
ChuckDriver
Not yet. Talked with Nate and he offered to send me another upper mount if I damage it when I remove it. I will re-weld it in the correct spot, using the motor mount plates to locate it.
Old 02-16-2015, 09:56 PM   #6
88CopperTop
Same here, he sent new mounts for us to weld on. Apparently we had one of the first dozen or so kits made and some things were off.
