Old 02-03-2015, 01:22 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Bumper Bolt Question
I have newly chromed bumpers ready to install on my 72 C10. I am a little confused about the bumper bolts. The bolts with the white head are the ones that were on the truck. The shorter chrome head one is what the chromer gave me with the rechromed bumper and these are chromed as well. The longer bolt is an NOS bolt t hat I had. Does anyone know which are the right bolts and why are the NOS ones so much longer. A Google search shows those bolts part# 340734 are for ann 85-87 C10. Did I buy the wrong NOS bolts?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-03-2015, 01:52 PM   #2
bluek5
bluek5's Avatar
Re: Bumper Bolt Question
I bought the same nos bolts. I am planning on cutting them down. The correct bolt would be ones like the one you removed from your truck. Both the nos and the original have a stainless cap on the head of the bolt. I would just go ahead and use the nos bolts.
Paul
bluek5 is offline   Reply With Quote
Old 02-03-2015, 02:01 PM   #3
SS Tim
SS Tim's Avatar
Your NOS #340734 is a service replacement part! It replaces a lot of earlier parts in the system with a one size works for most approach. Like I've tried to tell people so often a dealer or claimed NOS part rarely is a direct duplicate of a period production part.
Run the P/N through http://gmpartswiki.com using the "search" function and "all". Then you can see applications and supercessions with that number.
SS Tim is offline   Reply With Quote
Old 02-03-2015, 02:02 PM   #4
Lee H
Lee H's Avatar
The bolt on the right with the shallower head is correct for your 72 chrome bumper.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-03-2015, 02:28 PM   #5
davepl
davepl's Avatar
SS Tim, I disagree a little to the extent that what we -mean- when we say NOS is a part produced during the original production run. There are, as we see, a ton of service parts that often do the job but aren't correct for an original. So I'm only really picking a nit about the name.
Those would still be literally New Old Stock, but not what we usually want.
When searching on eBay, if it's got a bar code, I ignore it. I'm fairly certain GM didn't bar code in 1970. So definitely follow the gmpartswiki advice Tim gives. What I'm not certain is if a service part could ever carry the same part number as the production part, yet differ.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-03-2015, 03:03 PM   #6
Already Gone
I want to use the ones on the right that are solid and have been chromed with the bumpers and guess I will.
Old 02-03-2015, 03:35 PM   #7
davepl
davepl's Avatar
For some reason I remember JohnH telling me something about these bolts that surprised me. It couldn't have been that they're chrome. Either he said flash chrome or, more likely, stainless.
Anyone know what the originals were?
Old 02-03-2015, 07:15 PM   #8
Already Gone
The white bolts in the pic have the cap on them as do the "NOS" bolts. The ones the chromer gave me and chromed with the bumpers are one piece.
Old 02-03-2015, 07:17 PM   #9
bluek5
bluek5's Avatar
I disagree, I have 7 of these trucks at the moment. Everyone of them has the bolt with the more hemispherical head, except for one that is and older restoration.
Paul
Old 02-03-2015, 07:34 PM   #10
FirstOwner69
FirstOwner69's Avatar
My 69 came with stainless capped "high dome" (as called in some of the catalogs) carriage bolts as shown in post 9. However, all the high dome bolts I've seen in the catalogs have been chrome plated.
FirstOwner69 is offline   Reply With Quote
Old 02-03-2015, 07:54 PM   #11
franken
NAPA sells stainless bumper bolts if it helps.
franken is offline   Reply With Quote
Old 02-04-2015, 11:52 AM   #12
57larry
what would the correct part # be then if I went into Carquest or NAPA . Is it a Dorman part? thanks
57larry is offline   Reply With Quote
Old 02-04-2015, 12:01 PM   #13
Lee H
Lee H's Avatar
Paul
Thanks for sharing your experience. I could very well be wrong, I had my fresh restoration at the Brothers show a few years ago and was told by several folks, including the shows sponsor that the lower head bolt was correct for my 72 so I changed them out. I'll have to do some research and figure out which ones are correct.
Old 09-28-2023, 03:35 PM   #14
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm only bumping this thread because perhaps I can add some information on the subject, or even confusion. Better that then start a new thread perhaps.
I found these on my front bumper, I'd say they're original, we go way back. Two of six heads are different. They're all stainless. If original, then the factory had two types to choose from or it was intentional. That's not to say there aren't variances, and mine could be wrong as post 9 might imply.
Also for what worth, an image of the rear's as well. Those are stamped "P".
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
