02-03-2015, 06:14 PM | #1 |
Drum/drum brakes???
Is my 1970 C20 manual drum/drum brakes supposed to have a proportioning valve? And if I add a power booster, do you use a proportioning valve?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
02-03-2015, 06:51 PM | #2 |
20' Daredevil (Ret)
Re: Drum/drum brakes???
Nope. The prop. valve is to increase line pressure to front discs, as they require more than drums. Same with a power booster -- no prop. valve req'd with drum/drum setup.
02-03-2015, 07:19 PM | #3 |
Thanks for the info Mike
02-03-2015, 07:47 PM | #4 |
Correct. BUT, he does need a distribution block if for some reason he doesn't already have one.
02-03-2015, 08:10 PM | #5 |
I guess that is what was cut out of the brake system when the truck lived in the junkyard. Any clue as where I can get one of these? Look like a chevy dealer only part. Then again, I doubt a dealer would be able to get a 45 year old part.
02-03-2015, 09:27 PM | #6 | |
http://inlinetube.com/Prop%20Valves/PR-112.htm Maybe this ad on the parts board... looks like he's not responding though. http://67-72chevytrucks.com/vboard/s...d.php?t=658475 Last edited by FirstOwner69; 02-03-2015 at 09:33 PM. |
02-03-2015, 09:47 PM | #7 |
Thank you, I appreciate the links.
02-03-2015, 10:14 PM | #8 |
02-04-2015, 02:10 AM | #9 |
LMC sells them. Over $200 last time I bought one though... Distro block also provides the signal for your dash brake light - indicates when one circuit has been lost - safety feature.
02-04-2015, 07:27 AM | #10 |
www.classicparts.com has the distribution blocks for drum/drum for $80. They're out there and they're not expensive. I recently replaced mine.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-04-2015, 08:47 PM | #11 |
I've got a distribution block laying on the floor of my garage, took it off my running driving 68 C10 truck. Upgrading to disc brakes so I've got all new stuff. It's free to you if you PM me your address.
Phil |
02-04-2015, 09:01 PM | #12 |
Thank you Phil, much appreciated. I'll PM you.
