Old 02-03-2015, 10:25 PM   #1
tinsoldier
tinsoldier's Avatar
Wiring help for Engine Coolant temp
So I bought a used harness from a guy. I am trying to sort out the wirings. Well for some reason the ECT (engine coolant temp) was missing. I went to a junk yard and found a plug. My question is. I have identified the pin 74 from the blue connector c1 as the yellow wire (that is the ECT sensor signal). Where does the black wire goes?
Does the black wire go to ground? I can't find any pin on both the blue and red connector for the black wire of the ECT.
This is a 2001 truck harness.
tinsoldier is offline   Reply With Quote
Old 02-03-2015, 11:43 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Wiring help for Engine Coolant temp
It goes to "low reference" pin 80, it's a gray wire.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-04-2015, 09:06 AM   #3
tinsoldier
tinsoldier's Avatar
Thanks Ls1nova71..I actually found a low reference wire that goes no where.
