Old 02-04-2015, 06:06 AM   #1
mpierce9
A/C removal
I've got a 75 blazer with factory A/C. None of it works. The compressor doesn't kick on and I'd guess it has leaks in the system. I'm interested in restoring it some day but not at the moment. For now can I just remove the compressor and pressure lines? Does that create any risk to the parts that I leave on the truck?
mpierce9 is offline   Reply With Quote
Old 02-04-2015, 10:27 AM   #2
D13
D13's Avatar
Re: A/C removal
Why remove it? It' not hurting anything.
If you open it up, you risk getting contamination in any parts that may be good. You would have to cap the openings. but there really isn't any reason to remove them unless the compressor is locked up or locked on creating a major drag on the belts.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-05-2015, 10:07 AM   #3
77c10
77c10's Avatar
Re: A/C removal
Just remove the AC belt and carry on...
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 02-05-2015, 10:51 PM   #4
mpierce9
Re: A/C removal
I guess I'd like to remove the unnecessary equipment to give me room to work on the engine and clean up under the hood. The compressor doesn't work and all the a/c wiring is messed up and cut up also. I was just aiming to clean things up.
Old 02-06-2015, 12:20 AM   #5
Just call me Sean
Just call me Sean's Avatar
Re: A/C removal
It's not exactly unnecessary equipment.
Almost every truck I have bought was missing the compressor, brackets and lines. Stupidest thing previous owners always seem to do. Pisses me off.
It's your truck though. You will contaminate everything in the system.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 02-06-2015, 10:38 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
Re: A/C removal
Thats usally what I do too,but you still have the larger air box to stare at.
And a AC truck only has the one kick vent too,some do swap to the vintage
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
