Old 02-04-2015, 07:15 PM   #1
SS317
SS317's Avatar
66 C10 ball joints
I've read so many brake upgrade threads that my head is spinning.
Truck is 66 C10, Drum, Drum, stock front end.
I am taking my truck in Friday morning to get an alignment. It's been pulling to the right and I don't want to wear the new tires the wrong way. I'm planning on upgrading to front disc brakes eventually but budget does not allow it right now. Question is, if I have to replace the upper and lower ball joints, will the 73-86 ball joints fit the stock spindles? I know I have to upgrade the spindles to do my disc upgrade but that could be a year or so down the road and I need to drive my truck.
Thanks.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 02-04-2015, 11:10 PM   #2
Tree-50
Re: 66 C10 ball joints
I believe it is separated
63-70 ball joints
71-72 ball joints
73-87 ball joints
Ball joint must match spindle IIRC so, you should get factory ball joints and when the time comes get the 63-70 spindle.
Someone correct me if I'm wrong
Tree-50 is offline   Reply With Quote
Old 02-05-2015, 08:16 AM   #3
PGSigns
PGSigns's Avatar
You can get a drop spindle to match your current ball joints when you do the disc brake swap. If you are just going to use a stock spindle then you will have to swap the ball joints when you make the change.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
