02-04-2015, 08:41 PM | #1 |
72 trailing arms on a 65
Can someone verify if trailing arms and shock mounts from 72 c10 are the same as a 65. Thanks in advance
02-05-2015, 01:32 AM | #2 |
60-66 Nut
Re: 72 trailing arms on a 65
Yes the trailing arms are the same from '63-'72. However the '67-'72 lower shock mounts are different. Although I believe they will work. I prefer the '63-'66 lower shock mounts as they give better support IMO.
02-05-2015, 09:29 AM | #3 |
I put 71 trailing arms on my 65 and they fit great. The only difference I could find is the location of the parking brake mounting clip is different. New bushings from my 65 fit great.
02-05-2015, 12:23 PM | #4 |
Thanks for the info guys. Looks like I will proceed to buy the 72 frame. It supposed to have PS box, PB and discs so Captain I will be bugging you at some point for some brackets.
Thanks again |
