Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-04-2015, 11:52 PM   #1
muckyp
muckyp's Avatar
Kick panel speaker enclosures
Are all the kick panel speaker enclosures created equally? I looked at some the other day and was surprised how thin the plastic was for $90. Maybe that is the standard but that was the only set I have ever had my hands on. I believe they said these were made in Mount Vernon, TX.
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 02-08-2015, 06:55 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Kick panel speaker enclosures
Every plastic pre-made kick enclousure I've seen has been the cheap plastic kind. I wouldn't want to run them as is, I'd want some fiberglass layed over them or something for strength since they are by your feet. I ended up paying a couple hundred for custom wood+fiberglass kicks in my old 79 c10 and they worked awesome. Sold the truck, kept the kicks for future use.
Old 02-23-2015, 05:14 PM   #3
England72
England72's Avatar
Jegs has them for $68
http://www.jegs.com/i/RetroSound/700...96772/10002/-1
They are a lot sturdier installed. they fit flat against the metal.
England72 is offline   Reply With Quote
Old 06-03-2015, 05:46 PM   #4
jessemthompson
I am considering a set of these along with some 6x9s in the can corners
jessemthompson is offline   Reply With Quote
Old 06-07-2015, 12:56 AM   #5
muckyp
muckyp's Avatar
Anyone know if any of these kick panel enclosures will work with vintage air?
70 SWB 454/TH400
Old 06-08-2015, 11:53 AM   #6
Willie Makeit
Willie Makeit's Avatar
you will need to relocate your high beam switch using the retro sound kickpanels.
Willie Makeit is offline   Reply With Quote
Old 06-13-2015, 11:43 AM   #7
shawley
I'm really not a fan of these plastic kick panel speaker enclosures. I've been selling car audio for 10 years, and anytime we've done these, with a good high end speaker (Focal 165KRX2 or 165KRC, etc) they do not fit.
However you could easily take these as a template and fiberglass over them, and make them deeper so you can properly fit a good speaker. These from factory are designed to run a crappy $50-$100 basic speaker.
Watch for a future thread when I get a chance to install my stereo and I'll be doing custom kick panels
shawley is offline   Reply With Quote
Old 07-01-2015, 01:40 AM   #8
68c10airstream
68c10airstream's Avatar
I made my kick panels out of 3/4" mdf as the base panel and found tin buckets at tractor supply that had the same diameter at the base of the bucket as the speaker opening. I angled the bucket when i cut the upper portion off of it. I then cut slits in the rim and bent them out 90 degrees and riveted these legs to the mdf. I then purchased a gallon of evercoat body filler (on sale for about $18.00) and filled around the outside of the bucket going from the speaker edge to the outer edge of the kick panel to give it a teardrop look, all smoothed out. I chose this method as i have worked with body filler but only once with fiberglass
My objective with the tin bucket and body filler was to give the panel some solid body for the bass punch. I put some fiber fill down inside before i installed the speaker. My mounting screws are hidden inside the speaker hole. I painted the bondo buckets the same color as the inside of the truck
I installed polk MoMo's 6" in the kick panels and made mdf box's holding 10" subs behind my seat pointed up at my back, sitting at floor level. Seat almost rubs speaker face. No amp yet but sounds good to me. My audio ears are pretty picky as i have Dynaco tube amps in my living room driving Klipsch klf 20's
My truck system is a sony head unit indash that can load a cd behind the face as it folds open, i run a remote Sony Minidisc (yes a Minidisc) in the glove box that holds 5 minidisc's. Love the minidisc's for their cd quality, re-recordable, don't skip, can't scratch them, and are very small. No offense here but i hate digitally compressed music being played loud, just sounds wrong.
68c10airstream is offline   Reply With Quote
Old 07-02-2015, 01:08 AM   #9
UKNOWME
UKNOWME's Avatar
68c10airstream, Any pics of the kicks?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 07-02-2015, 09:53 PM   #10
68c10airstream
pic of kick panel
http://67-72chevytrucks.com/vboard/p...ictureid=21559
Old 07-04-2015, 03:22 PM   #11
_Ogre
_Ogre's Avatar
to get the best sound out of a speaker it needs an enclosure behind it
make your own out of fiberglass and mdf
while these are for my 58 the method is the same for any kick panel
with my vintage air
shop air compressor timer
Old 07-13-2015, 01:12 AM   #12
Zane M
I made my own for 73-87 squares out of the existing kick panel and the speaker pod out of a 2nd gen S series Blazer.
I would love to provide pics, but unfortunately my system got stolen out of my truck last night.
Zane M is offline   Reply With Quote
Old 08-10-2015, 12:13 AM   #13
UKNOWME
UKNOWME's Avatar
How about this?
1964 Chevy c10
