02-05-2015, 02:03 AM | #1 |
Next step
Currently have c notch and bags but want to go lower. What's the biggest notch I can do with the stock trailing arms?
What's the best most affordable kit? Search disabled? |
02-05-2015, 02:34 AM | #2 |
Re: Next step
You have a couple options depending on how much you want to spend.
Porterbuilt has arms that have more drop and I believe will clear the frame. You can either go with all his stuff of then piece together the rest of what you need: http://pbfab.com/63-72-stage-2-deluxe-rear-kit No Limit has a rear frame section that raises everything 4 inches: http://nolimit.net/products#!/C10-Re...tegory=6157532 Or you could Z the rear frame: http://67-72chevytrucks.com/vboard/s...d.php?t=485504
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-05-2015, 02:44 AM | #3 |
Re: Next step
I'm on a budget so it needs to be cheap.
Can't i do a 6" notch and relocate my bags to get lower? |
02-05-2015, 02:49 AM | #4 |
Re: Next step
You can. You limit will be when the arms hit the frame. If you arent laying out up front then you may never notice. Take a look at this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=593436
02-05-2015, 03:38 AM | #5 |
Re: Next step
Thanks man. Good info in that thread. I think I'll go with his setup. Seems simple enough. Bigger notch and run the bags off the axle. Should get my rear end down another 3-4".
02-05-2015, 08:13 AM | #6 |
Re: Next step
Flipping the front brackets will help keep the pinion angle under control as you drop it lower.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-05-2015, 11:57 AM | #7 |
Re: Next step
02-05-2015, 01:38 PM | #8 | |
Re: Next step
02-05-2015, 02:44 PM | #9 | |
Re: Next step
The brackets that your trailing arms are connected to in the front. You can grind/drill out the rivets and bolt the brackets back on upside down. You can also add a aluminum spacer in between to help center your wheels.
