Old 02-05-2015, 09:40 AM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
87 sputtering acceleration
bought a 87 truck with 305 that has been sitting for several years, so far i have put a new fuel pump and tank, and a tune up. it will sit there and idle good but when you start to take off and pushing gas 1/8to1/4 it has a sputter and sometimes will die, but when you push gas further it will smooth out and take gas good.
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 02-05-2015, 06:46 PM   #2
bhuffstutter
Re: 87 sputtering acceleration
Have you rebuilt the carb?
bhuffstutter is offline   Reply With Quote
Old 02-05-2015, 08:41 PM   #3
RUN GMC
RUN GMC's Avatar
If it is fuel injected.....i would check the fuel lines if rubber to see if they are mushy the insides will choke off fuel at times after sitting for a long time.....also did you change out the fuel sock they can get weak and choke off the suction.........
RUN GMC is offline   Reply With Quote
Old 02-05-2015, 08:51 PM   #4
greg64
greg64's Avatar
How about the fuel filter being bunged up? I'd think an 87 would be TBI. If so, check to see if any codes are set on the computer. Could possibly be the throttle position sensor that's bad (akin to a defective accelerate pump on a carb).
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-05-2015, 09:56 PM   #5
wlf89
wlf89's Avatar
yes, it is tbi.
i have changed the fuel filter, hoses, and the pump sock.
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 02-06-2015, 09:01 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
clean out the tbi good probably some junk in there
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-06-2015, 10:28 AM   #7
badchevy
My 87 also sat for a couple of years and does the same thing as yours. I have done the same things you have to yours and it still sputters upon acceleration. Mine got a little better after I blocked off the vacuum line going to the cruise control. I also got a "check engine" light come on and a 33 code showed up. It's for the IAC but every test I performed shows it's good. Might still replace mine just to see if that fixes it.
badchevy is offline   Reply With Quote
Old 02-09-2015, 04:59 PM   #8
ZacharyDouglas1992
1)Throttle body base Gasket
2)EGR (you can test this by removing the vacuum line and plugging it. If the sputtering stops, there was your issue. may cause your light to come on.
3)Idle Air Control Valve- as someone above posted, I tested my original one and it checked out, but on a whim replaced it anyways and it made a huge difference.
1967 CHEVELLE MALIBU 427/700R4
1971 CHEYENNE 10 350/350
1983 GMC K3500 454/400/205
1987 R10 TBI 350/700R4
2014 CRUZE 2.0 TURBO DIESEL
ZacharyDouglas1992 is offline   Reply With Quote
Old 02-15-2015, 08:14 PM   #9
badchevy
Just an update for you. I got a used IAC and installed it on my truck. Although I have only taken it out once, the truck seems to be driving a lot better and not cutting out like it used to. I will need to take it out for a good long drive to see if it really fixed the problem or not. Will keep you posted.
Old 03-07-2015, 09:50 AM   #10
wlf89
wlf89's Avatar
i replaced the tps because mine checked to be bad, and it was throwing a 13 oxygen sensor code and that also said check the tps sensor, but it didnt change the way it ran one bit that i could tell.
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
