Old 02-05-2015, 12:17 PM   #1
1972BlueC20
1972BlueC20's Avatar
Fuel Pressure Regulator Leaking
I tried installing an Edelbrock fuel pressure regulator recently because I wanted to get my pressure down to a constant 5.5 PSI since I'm running an Edelbrock # 1406
I got everything hooked up, but all the fittings I just installed were leaking fuel....not gushing but slightly leaking....everything was really tight....I removed the regulator completely from my truck and put everything back the way it was until I can get everything sealed up properly
I'm assuming I need some kind of teflon tape or thread sealer maybe?
Anyone ever had this problem?
Whats the best thing to use for sealing fuel fittings. They are 3/8 NPT
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 02-05-2015, 12:37 PM   #2
67 cst swb
67 cst swb's Avatar
Re: Fuel Pressure Regulator Leaking
With NPT threads, you will always need Teflon tape or "pipe thread dope" paste.
They are a unique tapered thread that requires thread sealant.
http://www.trentonpipe.com/ti_threadformdatachart.html
How to install:
http://www.entegrisfluidhandling.com...ct.aspx?G=1054
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-05-2015, 12:41 PM   #3
EdSevered
EdSevered's Avatar
I did the same upgrade (different fuel regulator) to my truck a few months ago. It was recommended to use teflon tape on all the threaded connections, which I did. No leaks. Good fuel pressure control. Some recommend Teflon paste instead. I believe both will work and it is a matter of preference. I find the tape to be easier to work with and provides a neater appearance. Someone will correct me if I am wrong.
-Ed
EdSevered is offline   Reply With Quote
Old 02-05-2015, 01:24 PM   #4
1972BlueC20
How to install:
Man you rock
You helped me on both my issues today LOL
Old 02-05-2015, 01:25 PM   #5
1972BlueC20
-Ed
Thanks Ed!
Old 02-05-2015, 06:37 PM   #6
dirtyjim
dirtyjim's Avatar
i prefer the paste, I've had a piece of Teflon tape stick between the needle and seat.
I use gasoila paste you can get it at tractor supply, its used for assembling gas pumps
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 02-05-2015, 06:53 PM   #7
1972BlueC20
Thanks man, I'll try to get some of this stuff
