frame rivets size
What size are the rivets in the frame
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: frame rivets size
In between 3/8 & 7/16. There is size between them that is a perfect match, but isn't made anymore. I am drilling my holes for 7/16 rivets in the crew frame.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
![]() Join Date: Dec 1999
I have some somewhere I will see if I can find them
Does the frame use the same size rivet on the hole frame
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop Last edited by 70cst; 02-07-2015 at 07:19 PM. |
![]() Join Date: May 2003
The frame rivets are 11/32 but are very difficult to find. The next size up is 7/16.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
3/8" grade eight bolts were used as the assembly line repair for miss hit or missing rivets.
Is there a reason you want to re-install a rivet rather than a bolt? K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I'm going back to original thats why I want to know what size
No problem.
Just wanted to make sure you were aware that a bolt is an acceptable GM authorized repair, in case you could go that way. K
So whats the right size
11/32 is the original size, but you may not be able to find any. So the next best thing is to step up to 7/16. That's what I did.
Yep, I've replaced most of the rivets in my frame with grade 8 7/16.
#12 | |
http://www.rivetsinstock.com/rivets/...id-rivets.html |
#13 |
Do I have to do any drilling
#14 |
SWB 4x4 Collector
Yes you will have to drill to the 7/16 hole id.
#15 |
A good bit will need to be used if your replacing a lot of rivets. I've went through two high grade bits, but I've also replaced nearly every rivet with a 7/16 bolt.
#16 |
Are there different lengths I need to know
#17 |
Which rivets are you replacing? I used a few different lengths in a few different places. I also used a washer on the top and bottom along with a lock washer. That took a little longer bolt in some places. Here's how the order went, bolt, flat washer, frame/cross member, flat washer, lock washer, nut. I think for the most of the cross members I used 1 1/4" to 1 1/2".
#18 |
What length rivets
#19 |
There are different lengths depending on how many layers of steel the rivet has to pass through. I believe it's Big Flats rivets site that has the instructions, maybe other sites do also. I bought like 1-1/2 in rivets and cut them to the proper length using their formula.
#20 |
http://bigflatsrivet.com
Here's a link to Big flats, they have the instructions down at the bottom of the page on the left.
