Old 02-05-2015, 01:23 PM   #1
rickoner
*Official* Post a pic of your new truck parts thread.
Figured this would be a good idea for a thread.
Parts have to be new or "reclaimed" for use on your truck. Also, the pictures have you be your own. No use of stock photos or ones from other sources allowed.
I'll start. Here are some that came in today.
Complete 292 gasket set, carb rebuild kit, water pump (unfortunately showed up broken), thermostat, and bypass hose.
(4) airlift D2600 bags, front mounting plates, step notches, some hose and fittings, and a temp ball valve
Ok, your turn. Lets see what you got for your truck today...
rickoner is offline   Reply With Quote
Old 02-05-2015, 02:45 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: *Official* Post a pic of your new truck parts thread.
Didn't come today. But to help get the thread started. New 100 amp chrome alternator for my 292.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-05-2015, 02:53 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
My Vintage Air AC unit with the controller and ashtray faces painted to match…
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 02-05-2015, 03:02 PM   #4
pimpston65
pimpston65's Avatar
i got a "new" title...
pimpston65 is offline   Reply With Quote
Old 02-05-2015, 03:29 PM   #5
NevEno
NevEno's Avatar
Cool idea! I got my new steering column and shifter linkage in last week.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 02-07-2015, 09:39 AM   #6
verdell
verdell's Avatar
My new carpet from Stock Interiors!
verdell is offline   Reply With Quote
Old 02-07-2015, 09:55 AM   #7
LVPhotos
LVPhotos's Avatar
Transmission in a box. Fresh from chrome.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-07-2015, 03:35 PM   #8
Johnny Too Bad
Johnny Too Bad's Avatar
New chrome grille
1964 Chevrolet C10 SWB Stepside (350cid/TH400)
1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400)
-"Ah, the pressure's fierce!"
Johnny Too Bad is offline   Reply With Quote
Old 02-07-2015, 11:06 PM   #9
koolkat269
Went to the Kalamazoo swap meet today and started out with these. Then ended the day with getting an 86 rolling chassis from Tennessee with the power booster and dual exhaust.
koolkat269 is offline   Reply With Quote
Old 02-07-2015, 11:23 PM   #10
Mjminino
Pic 1 - Entire floor Pic 2 - Entire suspension Pic 3 - Ball joints, tie rods, and energy suspension bushings Pic 4 - Door bottoms L/R
Mjminino is offline   Reply With Quote
Old 02-09-2015, 09:21 AM   #11
disasterbus
Popped in to my local Hot Rod shop ( yes, there are one or two in England ), literally only looking for a shouldered bolt for my steering wheel boss and came out with this Mooneyes steering wheel.
disasterbus is offline   Reply With Quote
Old 02-27-2015, 03:53 PM   #12
rickoner
These came in 2 days ago from Summit. Wire harness and 5 lug swap axles and drums.
Yesterday, I made the drive up to see Pimpston65 and did a little trading. I got a high hump trans tunnel and a sweet rad. Thanks again, buddy.
Old 02-28-2015, 08:28 AM   #13
bj383ss
bj383ss's Avatar
More paint...
20150225_192903 by bjohnson388, on Flickr
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 02-28-2015, 09:37 AM   #14
dodgiesdad
dodgiesdad's Avatar
If opening the box counts. Here is the test fit of my aluminum grill I picked up at Carlisle last year. With the new headlights I got from summit yesterday. I apologize I have tried half a dozen time to rotate this the right way without luck. So you may have to turn you head sideways to see it.
dodgiesdad is offline   Reply With Quote
Old 02-28-2015, 03:45 PM   #15
63longfleet
Just need some good weather now
Fed x dropped them off yesterday in the middle of a snowstorm and i work on mine in the driveway no shop
63longfleet is offline   Reply With Quote
Old 02-28-2015, 04:12 PM   #16
seanrolandwood
woke up to loud pounding on door, on trac delivery??? and now it looks like im gonna have to wife this one.........my birthday is in November Christmas happened already but she said it was just something she wanted to do...she went through my summit wish list and i will forever leave my laptop open to the page...got the 041 heads a few weeks back...block off to the builder monday keep y'all updated when its back....it's gonna be a good Saturday every weekend should start this way
seanrolandwood is offline   Reply With Quote
Old 02-28-2015, 06:04 PM   #17
LVPhotos
LVPhotos's Avatar
Flex-a-lite Black Magic 3300cfm fan. McLeod hydraulic clutch bearing.
Old 03-01-2015, 03:06 PM   #18
creep
Registered Loser
creep's Avatar
Dang. This thread makes me wanna build another one.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 03-01-2015, 03:56 PM   #19
Hollow65
Hollow65's Avatar
Depressing... Mine runs and I'm wishing I had more parts to put on now.
Seanrolandwood, did you get the 2.02 041's or the 1.94?
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-01-2015, 04:34 PM   #20
seanrolandwood
They're the 2.02/1.60 64cc heads they were redone in august for my dad but he took pitty on me when we found my old heads to be shot, that's what started this winters project of replacing everything underneath from radiator to rear end when it backs out the driveway next weekend that will be the first feet on anything 0 miles on motor trans rearend
Old 03-01-2015, 04:53 PM   #21
Hollow65
Hollow65's Avatar
Sweet! Best of luck to you, go easy on the new stuff for a while and be sure to change the fluids after a few hundred miles. External magnets on the pans helps keep the crap at the bottom of the pans.
Old 03-05-2015, 01:31 AM   #22
63swag
63swag's Avatar
[IMG][/IMG]
My haul for this week: full harness, new head lights, led tail lights, park lenses, dome light, door felts and weather stripping, mirrors, braided wire loom, grommets, zip ties with clips, custom cab trim, windshield trim, and a new set of dura blocks.
63swag is offline   Reply With Quote
Old 03-05-2015, 07:38 PM   #23
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
I have to contribute something to this thread.. Great idea!
Here is my new rad I installed a couple of months ago.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-05-2015, 08:11 PM   #24
Jferrante
Jferrante's Avatar
15x7 and 15x8 Cragar Delux's and Hankook radials
Jferrante is offline   Reply With Quote
Old 03-05-2015, 09:32 PM   #25
LVPhotos
LVPhotos's Avatar
Brake lines for '62 came in. Though not for '62, new projectors for my one ton came in. Lightning idea for others.
