Old 02-05-2015, 04:21 PM   #1
Longhorn 70
Longhorn 70's Avatar
Why does my hood pop up by the cowl?
Why does my hood pop up by the cowl? Is it adjustment, bad hinges, bad hinge springs, government conspiracy to look at my emissions stuff, or just what happens when we get old?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-05-2015, 04:22 PM   #2
67 cst swb
67 cst swb's Avatar
Re: Why does my hood pop up by the cowl?
Its time for new/better hood hinges.
I think when you get old, less things pop up.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 02-05-2015, 04:41 PM   #3
michael bustamante
michael bustamante's Avatar
quit putting blue pills in the gas tank,
seriosly though, the hinges are worn out
1967custom
michael bustamante is offline   Reply With Quote
Old 02-05-2015, 04:48 PM   #4
Molberg
Molberg's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=319778
This worked for me
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 02-05-2015, 05:13 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
I had the same issue. I used to push down on the back of the hood to get it back down. Before too long one of the rivets broke and I needed new hinges.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 02-05-2015, 05:15 PM   #6
Resto-Rand
Pay attention to what Molberg said! Check that link.
I saw the original posted response from Huck, tried it, and voila!
1971 C-10 307 3OTT
Resto-Rand is offline   Reply With Quote
Old 02-05-2015, 06:41 PM   #7
Longhorn 70
Thanks for the link.
I sure miss the search feature. Sometimes the google search returns too much.
Old 02-05-2015, 07:12 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Yep it works
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-06-2015, 09:14 AM   #9
serge
serge's Avatar
Originally Posted by leddzepp View Post
Yep it works
Adjust bracket where it bolts to fender. I slid hinge up 1/8" at front bolt and that little bit of pivot in hinge made hood flush with cowl.
My hood was doing same thing. So I removed the hinges and they were sloppy at pivot points. Bought some used tight hinges from a member, installed them and hood was higher then cowl again. Oh! xxxxx.
But after adjusting they work great.
Hope that helps.
General Contrucktor
serge is offline   Reply With Quote
Old 02-08-2015, 12:12 PM   #10
OhioChevy
I had this to happen to my hood when I re-installed the hood. When you closed it the back of the hood on the driver side would pop up in the back. You had to push it down and it then would be okay. A guy I knew that has worked in a body shop for years was over one day and I showed this to him. He said it was just out of adjustment and he proceeded to adjust the hinges and the hood closed perfect. It just needed a very small adjustment to make it work. I had tried to adjust the hinges several times with the help of my son-in-law and we just didn't get it right.
Ray
OhioChevy is offline   Reply With Quote
Old 02-08-2015, 01:13 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
The hood hinges are likely fine. I've been through this before. Just clean the pivot points well then lubricate well. The hood will sit back down after.
Old 02-15-2015, 07:27 PM   #12
Longhorn 70
Thanks Guys....it was just what I needed. The hood now closes properly and sits properly as well.
I'll bet from the reduced wind signature I'll get over 20 MPG...Maybe not but it looks so much better.
Old 02-15-2015, 07:38 PM   #13
Sicklajoie
The Niner
Sicklajoie's Avatar
Good news!
