What are you wanting to get done on your truck this coming weekend
I sit here about two hours before my normal 3 day weekend starts. I have all these plans going through my mind on "what I want to accomplish on my truck projects this coming weekend.
For starters on my 68 project short/step side, 1 ton dually I am wanting to pull the front sheet metal as well as the cab so I can shorten 60 off the frame. I then want to finish welding the cab roof/back and start smoothing out the graft. Not sure if I will get that all done, but if I do, I also have new tie rod ends and power steering brackets that need installed on a 63 GMC 1/2 ton short/fleetside I am working on. My thinking on starting this thread is it would be kinda cool if "we all" could use this as a place to put upcoming weekend plans in. After the weekend we can post pics of what if any progress was actually made. Heck you might even get more done than you think. I usually don't get quite as much done as I was hoping for but sometimes. Maybe we can feed off each others progress and get inspired to get even that much more done. Who knows. It could happen. Chime in, the more the merrier. Don't worry of even sweat that old "thread hijack" cliché. Almost like a little challenge to ourselves to get done what it was we "said" we wanted to get done. Whattaya think. U in? I know I'm not the only one with plans for this weekend. Oh yeah, forgot, not everybody will have 82* weather this weekend. But still, you can get something done. Right? What? The key to this thread being anything at all is to actually come back next week and tell us how much got done. Pics will be all the more better. Let's inspire each other. The challenge is out. Anybody got any more ambitious plans for the coming weekend? ![]()
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
Re: What are you wanting to get done on your truck this coming weekend
I thought I was going to change the belt on my 68 yesterday.
327 V8 no power steering, no A/C Should take about 5 min. Right? WRONG! Bottom alternator bolt is busted off in the exhaust manifold. Now, my goal is: * Degrease engine * Remove manifolds * Extract busted bolt * Sandblast and coat manifolds * Paint brackets and pulleys (Rust Tough Semi-Flat Black) * Reinstall Manifolds, brackets & pulleys * .....Replace the belt |
I'm jealous of that 82* weather. 27 and snow flurries yesterday. And as far as this weekend, order some parts for the truck. Next weekend? Bring it home. We'll see how that goes.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Did the front springs and ball joints last weekend. Weather turned to crap and didn't get everything buttoned up and a test drive in. Still have to adjust the brakes and replace a couple of grease fittings.
Awesome. Just exactly what I had in mind. Now, the hard part, u gotta come back next week and tell us what you actually got done. Heck even ordering parts counts. Especially if it's cold. We do the polar opposite here. During the heat of the summer when you boys are digging in and getting it done, we don't hardly do nuthin.Too hot. 117* and humid. Stupid hot. My wife tells folks; "We moved to the Sun".
![]() Join Date: Dec 2013
Primed the bedsides today. (Wow are they big!) This weekend I am going to finish block sanding all the bed parts, hopefully shoot the color next week. Wood floor is all done, just waiting to be assembled.
US Army Veteran
![]() Join Date: Nov 2008
I've been collecting parts through the winter, waiting for spring. Cold weather didn't bother me when I was younger, but I now understand why old folks like to move to Florida!
It's supposed to warm up this weekend, if so, will get started sanding in preparation for paint next month.
1972 C10 Highlander - The making of a daily driver |
I'd like to at least start a complete brake re-do on my '70.
While Im there, I've got a leaky left rear tire I can get fixed. I'll need 2 more jack stands. At least it's inside, unheated tho. |
![]() Join Date: Sep 2007
i WAS wanting to start removing the rusted out cab mounts and weld in the new ones......
i broke my leg (fibia) in two places so now im stuck looking at the new classic industries catalog and playing with my gauges since thats all i can do on the couch. bummer are you selling cab parts? i need the two floor sections by the kick panals from firewall to the rockers about 6" wide
1967custom |
![]() Join Date: May 2012
I will put my heater box back in now that I have all the gaskets. This is the time of the year we work like crazy because it will be toooo darn hot!!
mike it's only 80 today
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
Disc brake conversion and lowering my current project about 5-6 inches on all four corners.
![]() Join Date: May 2013
Was going to pull the old block out of my truck and get ready to drop in the new, but rain is moving in. Not doing it in the rain. maybe I'll just get my oil pan on and finish the fuel line on the new engine.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
#13 |
I was planning on brushing the snow off my truck (again), and continue the countdown until spring!
Incapable of not thinking about my truck at least every other minute ![]() |
#14 |
Going to finish welding my floor pan this weekend and hopefully get the big hole above my heater motor in the firewall patched up. My welding skills this have proven lacking but I can't afford to pay someone to do it. I am managing to get lots of clean up and fixing done on my truck. Can't wait until April when the weather finally breaks and I can roll outside to get stuff done!
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! ![]() My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
#15 |
Probably won't get much done to the truck itself. I'm going to do some cleaning of the garage, hang the front sheet metal on the walls, throw away junk, and store the unwanted truck parts into my trailer along with the cherry picker that takes up too much space.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#16 |
Front hubs have to come apart tomorrow to access the gravel shields for the brakes. Shop that last did an axle rebuild didn't tighten the mounting bolts enough and after a few thousand miles both sides fell out. One shield got mangled, the other one is hanging in there by the upper tabs. Same shop quoted me $300 to fix the problem... think I'll just do it myself, correctly this time! A bit unsure of how to make the mangled shield work again, but since you can't buy '72 4x4 shields any longer, I guess I'll figure that out tomorrow before putting that side back together...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#17 |
Finish my under hood wiring.
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
#18 |
im looking at this new American autowire kit I bought. want to install it this weekend. looks like it will take me about 3 years to finish. that's a lot of wires!!! will probably strip and paint interior of cab instead.
#19 |
I guess I not only have my own to work on, but another one that has been getting my love and attention.
On my 69 Chevy C10, hopefully application of the LAST coat of varnish on the wood floor for the box, and if that happens earlier than planned, installation of the floor. The pickup that actually lives in the garage where my floor is (72 Chevy K10)...just took the instrument cluster out and added a tach/vac gauge kit, ran the wiring for it, and drilled/tapped holes for dome light switches. Guess it depends on my wood floor, but I'm guessing the 72 will end up with working dome light switches for sure. As long as I get to Napa tomorrow, then I should have the rest of the fittings for the tach/vac conversion and have that done. Now I would hope that ambition may be high enough to pull the seat out of that one and replace the fuel sending unit...guess time and help will determine that!
My friends describe my house as the small town used Chevy Pickup dealership. |
#20 |
![]() Join Date: Sep 2010
I plan on pulling the Dog House off... Fit and Align the Doors, install the basic door latches in for fitment and alignment... Pull the engine and Transmission to prepare it to go to Patterson Racing to be built... Drill side molding trim holes... Reinstall the Dog house and take it to the body shop for some minor "tweaking" if the cab to doors...
It is to be 72 here Saturday and 70 on Sunday so I should be able to get alot accomplished...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#21 |
Old member
Well I don't have a 3 day weekend but I do have tomorrow off and start night shift Sunday night so I have some time on Sunday to.
I want to get passenger side done. So I can drive the truck to work Sunday night. I need the cab corner speaker grill cut and installed and then the passenger side seat installed. I got the drivers side done yesterday. This is the second time to install them. I had to get new carpet installed since I had to move the gear shifter forward about 6" so the new console would fit. Yesterday was sub box, corner speaker, and seat and belts all installed. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#22 |
![]() Join Date: Jun 2004
Put the window down, turn the radio on, and cruz.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
#23 |
After weekend after weekend of other things ruining my plans for a little wrenching, it happens this weekend!!
Having bought my 72 K2500 in November, it's been a reliable daily driver. But I've not spent the time to crawl over and under it and just see exactly what I'm dealing with in detail. Also, shorten the steering column so my gut doesn't constantly rub the wheel. Oil/filter/lube. Replace the belts (one squeaks on cold start). Rip the old foam and upholstery off the original seat, clean and paint the frame, and store it properly awaiting a new foam and upholstery kit. Figure out exactly what I need to have a working parking brake. And spend some time on my back seeing how bad the cab rot is. So far, floorboards and rockers are a loss, but the corners seem solid. And if I have the time and can convince the wife to help, flush the brake lines with new fluid.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
#24 |
It's supposed to rain all weekend so...
![]() ... weld, sand, repeat. |
#25 |
New speedo cable, new parking brakes. Tired of driving around just knowing if I'm speeding or not.
