![]() Join Date: Mar 2004
Need measurements of trucks with lifts
I am trying to figure out if / how big of a lift is on my Jimmy.
Can anyone take a quick measurement from the center of their hub to the bottom of the fender and let me know if they are from a stock height, lifted, etc.... Thanks,
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Re: Need measurements of trucks with lifts
I believe mine has a 4inch lift?? It clears the 35x12.50R17 Toyo Mt's that are on it.
That's a nice stance but I just threw some 33x12.50x18s on mine which clear fine but I was just wanting to replace all the springs for shyts and giggles but had no clue what is on mine. I want to keep my stance. It looks like it at least has a 2" block on the rear pack but not sure if the PO was compensating for OG spring sag... Or?
Ok....can anyone measure their stock height at least?
Bueler?
Does anyone have a tape measure, and a blazer in their garage?
Post Whore
![]() Join Date: Feb 2000
I'll get a measurement of my K5 tonight.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
![]() Join Date: Jun 2012
My Jimmy has a 4" Tuff Country EZ ride all spring lift and it is about 28 1/2" from the center of the hub to the fender lip on both the front and the back wheels. Although, my Jimmy is not completely put back together yet so i still have weight to add to it and it has not been on the road yet. I am sure it will settle some yet. I believe that Tuff Country uses 6" springs on the rear axle of their 4" lifts for the Blazers and Jimmys so the back does not sag.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
Post Whore
I have 4" springs and I have a measurement of 25 1/2" for the front axle from the center of the hub to the bottom of the fender.
Junior Member
![]() Join Date: Oct 2005
These are 35'' tires. Suspension 6'' and 3'' body lift. Can't measure as I'm out of town until Friday.
1964 Chevy Suburban 4x4 1966 GMC Suburban 4x4 |
Heres a 6" + 3" body. Take out the 3" body and you have 30" from center of hub to fender lip
#12 | |
tuff71 do you have the engine and trans in? im needing a measurement for a 6" .is there any way you can measure from the top of the axle tube to the bottom of your frame? please thank you ![]()
Chris Heinz |
#13 |
That measurement would be 14 1/2" and yes I have the motor/trans in.
#14 | |
Chris Heinz |
#15 |
no problem
#16 |
my front springs are 13.5 to the frame. 29 from hub to fender.im guessing this would be 5 inch as hard as that is to believe
Chris Heinz |
