08-24-2003, 01:15 PM | #1 |
Got big-block?
Part 2: pulled the heads off a friends '72 last night....have a question
We got the piston tops all cleaned up.
What's the best thing to use to remove an ancient head gasket? I've got some gasket remover and a scraper, but is there an easier way? Grinding disc? What kind? Thanks, SC |
08-24-2003, 02:28 PM | #2 |
I've just used a putty knife/paint scraper. Took a while because I didn't want to scratch the deck.
I'd be very careful what kind of grinding wheel/disc you use. Good luck!
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
08-24-2003, 02:31 PM | #3 |
I used one of the 3M pads on a small angle grinder air tool and it cleaned things up nice. However, the guys at the machine shop were not impressed. They say it removes too much metal. I don't think it is too bad on the block but I don't think it should be used on aluminum parts.
1968 Chevy - 292 with a powerglide |
08-24-2003, 03:09 PM | #4 |
Dreams are free
a wire brush in you die grinder, nothing else compares!!
'68 swb fleetside originally w.i.p '68 member since 1-01 w.i.p = ( work in progress ) |
08-24-2003, 04:23 PM | #5 |
I use a staight razor blade, don't scrape too deep, don't want to shave metal.
That's right, I'm back in the game again. No it's not pink..... 1972 Blue and White Suburban. |
08-24-2003, 04:45 PM | #6 |
I LIKE TO USE THE 3M ROLOC DISCS THAT ARE MADE FOR GASKET REMOVAL. NOT!!!! THE FIBER ONES & NOT A WIRE WHEEL. I DON'T LIKE TO USE ANY ABRASIVE THAT WEARS INTO MICROSCOPIC PARTICALS, TO GET INTO PISTON RING GROOVES OR BEARINGS, CAUSING PREMATURE WEAR. I USE DIESEL FUEL AS A LUBRICANT TO LOOSEN UP THE CARBON BUILDUP. JOHN OR LIKE LUDWIG SUGGESTS..... A RAZER BLADE WORKS GREAT. WHERE HAVE I HEARD THIS BEFORE. LOL
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
