Old 02-05-2015, 10:13 PM   #1
Jferrante
Jferrante's Avatar
Air Drafts Coming through firewall
Need some help on finding some replacement firewall grommets for a 1964 c10. Everywhere I have looked and searched seem to be for different years. I am getting some serious drafts through the firewall when I am driving and need to replace some of the grommets. Let me know if anyone has a good source or alternative solution.
thank you
Jferrante is offline   Reply With Quote
Old 02-05-2015, 10:18 PM   #2
pimpston65
pimpston65's Avatar
Re: Air Drafts Coming through firewall
thank you
which ones are you needing?
pimpston65 is offline   Reply With Quote
Old 02-05-2015, 10:21 PM   #3
joedoh
joedoh's Avatar
if you arent doing a nut and bolt restoration, this stuff works really really well for sealing up holes and existing grommets, even if they already have wires/stuff in them.
http://www.nationaltoolwarehouse.com...FQiUaQodz0sAyw
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 02-05-2015, 10:27 PM   #4
Jferrante
Jferrante's Avatar
I was looking for an all new set
Old 02-05-2015, 10:27 PM   #5
Jferrante
Jferrante's Avatar
This is pretty cool I was reading up on the spray foam option and this looks cleaner
Old 02-05-2015, 11:28 PM   #6
ACK
ACK's Avatar
If the tranny has been converted to an automatic and the clutch pedal assembly removed, that leaves a huge hole in the firewall. A 1.5" electrical box plug from the local hardware store will fill it perfectly if it needs to be capped off.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 02-06-2015, 07:48 AM   #7
PGSigns
PGSigns's Avatar
I used the set from Brothers. They list it as fitting 60 to 66. I also used the box plug for the clutch hole. Mine also had a hole in each side that was for a plastic push pin for the stock fire wall insulation that was open. I got some to fit it at the auto parts store. I put a flood light in front of the truck with the hood open and went up under the dash at night and looked for light coming through. Looked like a starry night when I started. Now that the cab is sealed well the heater will run you out. I added a heater control valve to be able to adjust it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-06-2015, 11:00 AM   #8
chevyrestoguy
chevyrestoguy's Avatar
I did the same thing as Jimmy, and hung a drop light under the hood and closed it and then checked the firewall from the interior side. This way, you'll know which grommets to replace, and where to add silicone or filler panels.
I think this something that everybody needs to do. It makes a huge difference in noise and temperature control.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-06-2015, 11:34 AM   #9
Jferrante
Jferrante's Avatar
Thanks all - i will look into the brothers kit and add the 3M caulk where needed. My thoughts were to start from the engine bay and then look from the interior as well.
Old 02-06-2015, 12:27 PM   #10
blown240
blown240's Avatar
Thanks for all the tips in this thread! I am looking to do the exact same thing!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 02-06-2015, 12:54 PM   #11
Jferrante
Jferrante's Avatar
Great info and resources on this site for sure...i am in NJ and it is 17 degrees
Old 02-06-2015, 02:32 PM   #12
Micmac
Micmac's Avatar
I'm coming to Joisey, it was 9 here in the Blue Ridge this morning. Going up to 55 tomorrow, I'm taking the Chief out for a spin!
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 02-06-2015, 04:15 PM   #13
Jferrante
Jferrante's Avatar
I try and drive her daily since the porsche doesnt like salt on her
Old 02-06-2015, 05:08 PM   #14
Micmac
Micmac's Avatar
I hear ya bud. I hope it warms up soon, the propane guy just paid a visit, $568.23 since December 4th. That hurts!
Old 02-06-2015, 05:25 PM   #15
Jferrante
Jferrante's Avatar
eeeekkk---lterally busted an airline for my airbags on the way home just now....adding to the parts list.
Old 02-06-2015, 07:30 PM   #16
blown240
blown240's Avatar
YIKES! Thats never fun. I did that on the freeway at 60mph once in my 51. And i only had F/R bags, so the whole front dropped!
Old 02-06-2015, 10:08 PM   #17
Jferrante
Jferrante's Avatar
Yea thankfully it is only the fill hose and my bags are keeping the air that was already in them...when I go to fill it just leaks out. Off to truck supply tomorrow to find DOT air line
Old 02-07-2015, 02:48 AM   #18
joedoh
joedoh's Avatar
the semi truck place here carries air line, ask for synflex, it is the common name for DOT line. dont trust zip ties to keep your airlines captured either, use adel clamps
oh and I hope your truck parts place is open on saturdays because here they arent and they even close at 2 on fridays, thats how sure they are about not being open saturday
Old 02-07-2015, 07:01 PM   #19
Jferrante
Jferrante's Avatar
NAPA had the 3/8" - going to get under it on Monday - posted another thread in suspension cusnowmy compressor isnt turning on - has to be related to the busted line though
