Old 02-05-2015, 10:28 PM   #1
frankslagoon
heater control light ?
Does anyone have a 63 or older w/econo heater controls that has a light behind it?
frankslagoon is offline   Reply With Quote
Old 02-05-2015, 11:19 PM   #2
jbgroby
jbgroby's Avatar
Re: heater control light ?
My '60 gmc has a spot for a light as well
jbgroby is offline   Reply With Quote
Old 02-05-2015, 11:28 PM   #3
bhc41051
bhc41051's Avatar
I'm pretty sure the Deluxe Heater with the 4 levers had the light. The recirculating heater had the 2 levers and no light. Maybe the controls had a provision for the light but didn't have the grey wire to the fuse box. The diagram in the shop manual doesn't show the light wiring for the recirculating heater.
bhc41051 is offline   Reply With Quote
Old 02-05-2015, 11:38 PM   #4
frankslagoon
Sorry, C10 1963. I don,t see a place on mine with the 2 levers but I wonder if I can put the 4 lever plate on the back and just use the 2 levers. Hmmm?
Old 02-06-2015, 02:38 PM   #5
Micmac
Micmac's Avatar
My '63 has the Econo w/ no light.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 02-06-2015, 03:11 PM   #6
forestb
forestb's Avatar
My 62 has a single nob with a light inside it.
forestb is offline   Reply With Quote
Old 02-06-2015, 03:42 PM   #7
frankslagoon
Remember chevys a gmc dashes are way different is your 62 a chevy with a knob?
Old 02-06-2015, 03:48 PM   #8
Greg63
Enjoy your truck
Greg63's Avatar
I had a econo 2 lever without a light and I now have a deluxe 4 lever with a light in my '63 Chevy.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 02-06-2015, 03:57 PM   #9
frankslagoon
ok I'm gona grab a deluxe control and see if I can make a econo with a light out of the 2 of em
Old 02-06-2015, 04:02 PM   #10
forestb
forestb's Avatar
yes here is the best photo I have.
Old 02-06-2015, 04:12 PM   #11
Greg63
Enjoy your truck
Greg63's Avatar
That should be do-able.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 02-06-2015, 05:12 PM   #12
frankslagoon
Well I never seen one like that. nice lookin truck dude. mine has the sliders. how do ya adjust the defrost?
Old 02-06-2015, 05:15 PM   #13
frankslagoon
Greg
actually Greg it looks like the rivet holes are in different spots. gona be a bit more trouble then we thought.
Old 02-06-2015, 05:16 PM   #14
Micmac
Micmac's Avatar
Hey Frankslagoon anyway you could document the change over with photo's for the less mechanically gifted of us? I wasn't aware of the light option, but it sounds like a cool upgrade.
Old 02-06-2015, 06:02 PM   #15
Greg63
Enjoy your truck
Greg63's Avatar
Its been a while since I had mine out so I don't recall any rivets or their locations, but I do recall the housing that the light bulb goes into is above the control levers.
From the front they both appear the same except the econo heater control has the outer two slide slots blocked off from behind and the deluxe version uses all four.
You can see mine in this picture;
[IMG][/IMG]
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 02-06-2015, 06:41 PM   #16
frankslagoon
The rivet spots make it really hard to mount the 2 lever control in the 4 lever cover. you could do it but might be pretty sleazy.
Old 02-06-2015, 06:48 PM   #17
frankslagoon
Old 02-07-2015, 07:34 AM   #18
jbgroby
jbgroby's Avatar
The factory had a thin plastic or hard paper material mounted on the backside of the panel to block-out the voids. I would think with the thin plastics we can find today, you can put something like that or black backing tape in the insides of the delux box easily.
Old 02-10-2015, 07:42 PM   #19
frankslagoon
So. here,s what I came up with. There's not much room to work with. I screwed this one on but you could probably glue it. then just put one light hole in between the two levers. you have to stay as far forward as ya can or the box will hit the dash. and ya can't make it to wide or it gets in the way of the screw hole tabs. Actually you could just drill acouple small holes and put some miniature lights from radio shack in .
Old 02-10-2015, 09:13 PM   #20
Greg63
Enjoy your truck
Greg63's Avatar
Nice work.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 02-10-2015, 09:44 PM   #21
Jeff La
WOW great job
Jeff La is offline   Reply With Quote
Old 02-10-2015, 10:10 PM   #22
OldGMJon
OldGMJon's Avatar
Talking Re: heater control light ?
Better go get them lights quick cause radio shack just filed bankruptcy
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
