Old 02-05-2015, 10:42 PM   #1
still1graphics
Another Ez Air Ride installed and Ready to Roll....
Thanks again to Steve over at Ez Air Ride Suspension for the great kit for my C10 trucks! He's a great guy with years of air ride experience.... I plan to build another one soon!!!
still1graphics is offline   Reply With Quote
Old 02-05-2015, 11:00 PM   #2
still1graphics
Re: Another Ez Air Ride installed and Ready to Roll....
P.s. I put this kit on in about 4 hours me and my buddy. .. This kit is super easy to install and very reliable! More pics of my new build coming soon! !!
Old 02-05-2015, 11:20 PM   #3
still1graphics
Thumbs up Re: Another Ez Air Ride installed and Ready to Roll....
Here is a picture of the other truck hooked up with the Ez Air Ride Suspension kit! This is a nice little daily driver that rides soon smooth on air! This is the way to roll...
64' chevy c10 fleetside bagged with the classic ez air ride kit!
Old 02-05-2015, 11:52 PM   #4
still1graphics
Just a few pics from the install and sleek gauges!
Old 02-05-2015, 11:54 PM   #5
still1graphics
Gauges under the dash...
Old 02-06-2015, 07:53 PM   #6
66ZZ4
66ZZ4's Avatar
Still1 Love the 64. Looks killer. What size tire and wheel are you running and how wide are the white walls?
66ZZ4 is offline   Reply With Quote
Old 02-06-2015, 08:56 PM   #7
still1graphics
I think the tires were 205 / 75 / 15
And the white wall tires were 3" wide.
I sold the truck or else I would check?
Sorry I hope this helps?
Old 02-06-2015, 09:17 PM   #8
still1graphics
A few more of my old builds with the sweet Ez Air Ride Suspension from my good buddy Steve!!!!
This truck was a really cool little shop truck that was a blast to drive.....
Old 02-06-2015, 09:29 PM   #9
still1graphics
Another c10 step side slammed with the air ride!!!!
Ez Air Ride Suspension all the way....
It just doesn't get any better or easier!
Old 02-08-2015, 12:09 PM   #10
lolife99
67-72 parts collector,…
lolife99's Avatar
Any pics of the bag mounts?
Air line routing, etc?
Just trying to see what is different or the same about these kits.
Keith
Convert to disc brakes.
Old 02-09-2015, 08:59 AM   #11
SCOTI
SCOTI's Avatar
Seems like someone is advertising w/o stepping up to the plate.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-09-2015, 11:26 PM   #12
still1graphics
I did put the drop cups in the front a - arms to get it down a little lower! They really make a difference in the ride height if you like it low...
Old 02-09-2015, 11:29 PM   #13
still1graphics
I also mounted the tank where the space tire used to go and the compressor inside the frame rail. I like them way back in the rear so you don't even notice or hear it running!
Old 07-16-2016, 09:16 AM   #14
ColinPierce
on the first truck how much of a drop did you get? Also what ez air ride kit did you use? and did you c notch the frame at all?
ColinPierce is offline   Reply With Quote
Old 01-26-2017, 05:23 PM   #15
wolfsden
wolfsden's Avatar
Im looking to install the classic plus from EZ ride, I have a 63 C-10 will mine sit this low front and back or did you do other mods to get it that low?
wolfsden is offline   Reply With Quote
Old 01-26-2017, 05:37 PM   #16
bbbc10
Diggin The SquareLife
if u want to sit low u will have to notch them frame an cup the lower control arms or section the crossmember etc.....put air ride on a in modded truck will only be few inches of drop
bbbc10 is offline   Reply With Quote
Old 01-26-2017, 05:43 PM   #17
MikeB
MikeB's Avatar
Having owned a 69 C10 and looking at all the parts in the kits, I would have guessed an entire weekend or more. Or were the old springs already removed, air lines already run, etc?
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-26-2017, 07:44 PM   #18
SCOTI
SCOTI's Avatar
After you've done 5-6 drops on the same style truck suspension & you do each truck w/the same kit, the repetitiveness significantly helps chip away the time frame. Maybe not from an 'entire weekend' to about 4hrs hours but it def doesn't hurt knowing the territory.
This kit is no better vs what Travis @ AZ Performance can/does offer & Travis supports this board.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2017, 01:38 AM   #19
wolfsden
wolfsden's Avatar
ok so what your saying is to do 2-1/2 drop spindles in front and c notch in back plus the EZ ride air bag kit to get it real low?
Old 01-28-2017, 04:00 AM   #20
bbbc10
3" drop spindles plus any of these mods..section crossmember plus cup lower control arms remove inner fenders an trim the fenders....rear 10" deep notch an cut the middle of the bed out to clear an maybe mod the rear tubs.....ur only gonna get a inch or 2 more than the lowest static drop u can buy for ur truck
Old 02-12-2017, 05:59 PM   #21
wolfsden
wolfsden's Avatar
Does the Chevy in this pic have any other lowering devices installed other then the EZ air ride?
1963 Chevrolet C-10
