Old 02-06-2015, 12:59 AM   #1
kmfb
Can I modify my Champion radiator for my LS swap?
So I have a 79 swb and had a 350 in it. I purchased a 3 row Champion Radiator with dual fans for it but never installed it. I ended up having issues with the motor and decided to sell it and the transmission off to swap in a 2003 5.3/4l60e combo. I know the outlet on the Champion radiator is on the driver side and the LS requires it to me on the passenger side. My radiator does have the internal tranny cooler built in as well. I'm wanting to know if I can basically cut off my outlet and move it over to the passenger side? I have seen some tahoes with the outlet hose that runs back across the radiator to the passenger side but I think its kinda ugly looking. I would like to utilize this radiator and fan setup if possible. Any help would be greatly appreciated!
Kyle
kmfb is offline   Reply With Quote
Old 02-06-2015, 01:08 AM   #2
First c10
First c10's Avatar
Re: Can I modify my Champion radiator for my LS swap?
This is the champion radiator I used. I am not sure you can move the stub because the tanks are not divided. So if you move it the water will not flow throw the radiator but just flow throw the tank.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-06-2015, 01:22 AM   #3
kmfb
That looks like the exact one I have. What did you or are you planning to use for the upper hose?
Old 02-06-2015, 01:43 AM   #4
First c10
First c10's Avatar
I used a stock hose from a 2011 chevy truck. Then after I cut the hose in half. Used a piece of stainless steel polished it up and made some custom aluminum brackets. I was looking for a picture but I can't seem to find one. I will try and take one tomorrow.
GO GO!!!
Old 02-06-2015, 01:52 AM   #5
kmfb
I would appreciate that!
Old 02-06-2015, 10:07 AM   #6
Indian113
Indian113's Avatar
this is how I did mine
Indian113 is offline   Reply With Quote
Old 02-06-2015, 10:41 AM   #7
kmfb
Is that in an s10? Looks good! Any top views of that hose setup by chance?
Old 02-06-2015, 11:11 AM   #8
Matt Cramer
Kyle
Moving the outlet is not likely to work unless the passages in the radiator are vertical. However, I had no trouble making a stock 1972 radiator with a driver's side top outlet work with an LS swap using a top radiator hose for a 2005 Silverado. I suspect the same will work for you, assuming this is a direct fit radiator.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 02-06-2015, 11:16 AM   #9
kmfb
Yeah I want to keep my aluminum radiator, I'll probably just modify the upper hose with stainless tubing. Just need more pictures for references.
Old 02-06-2015, 11:59 AM   #10
Indian113
Indian113's Avatar
Yes it's my S10. I have 1 pic but it's not very good. I'll try and take another today after I dig it out of the snow bank
Old 02-06-2015, 01:46 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Mines not a Champion, but I use made a stainless tube crossover just the same.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-06-2015, 04:23 PM   #12
BigRed76
BigRed76's Avatar
Is that just sections cut out of the stock upper hose?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 02-06-2015, 04:45 PM   #13
Indian113
Indian113's Avatar
Big Red yes it is.
Old 02-06-2015, 06:03 PM   #14
BigRed76
BigRed76's Avatar
Big Red yes it is.
It looks much better than the 4 ft. long stock hose
Zach
Old 02-06-2015, 07:34 PM   #15
Indian113
Indian113's Avatar
Is this what your wanting to see? I took out the tubing on water pump and modified it then moved it allow a better connection. It started to leak so I used a little JB Weld to seal it and haven't had any trouble since. Because of the limited amount of room under the hood of a S10 I needed to put my space to good use.
Old 02-06-2015, 07:37 PM   #16
First c10
First c10's Avatar
This is my top radiator hose!!!
GO GO!!!
Old 02-06-2015, 08:03 PM   #17
Indian113
Indian113's Avatar
That looks nice
Old 02-06-2015, 08:53 PM   #18
Marty68
that looks really nice. i dont have a radiator yet (old one was stolen for scrap) trying to decide electric fans or not if not i wouldnt have to buy a shroud. if i dont have a shroud i thought the 4 foot rubbe rhose would look crappy.
Marty68 is offline   Reply With Quote
Old 02-06-2015, 09:53 PM   #19
First c10
First c10's Avatar
Thanks!!!
GO GO!!!
Old 02-07-2015, 09:56 AM   #20
homemade87
Heres mine on the 82 with electric fans stock radiator. Hose is from a 04 silverado.
homemade87 is offline   Reply With Quote
Old 02-07-2015, 10:59 AM   #21
chevy-fun
chevy-fun's Avatar
can you explain how you did that. pipe, clamps??
chevy-fun is offline   Reply With Quote
Old 02-07-2015, 11:46 AM   #22
First c10
First c10's Avatar
Sure... the stainless steel pipe is 1-1/2" ID process piping from a cheese plant I worked at. It already had the 90* elbow welding on I just cut each end to the length I needed and polished it. The mounts are 1" x 1/8" aluminum flat plate I formed and polished, Added 1/16" rubber pad and bolted to the top of the radiator at the shroud mounting bolts. Just cut the stock hose and clamped on each end with high quality SS hose clamps.
hope this helps
Scott
GO GO!!!
Old 02-16-2015, 09:54 PM   #23
kmfb
Very nice! Thank you for the picture!
