![]() Join Date: Jan 2011
Clearance under rear bench seat.
Hello guys,I'm going to put a subwoofer under rear seat,need to know what size subwoofer will fit under 1970 gmc factory rear seat,I don't have my seat at this moment,measuremen needed,thanks.
![]() Join Date: Mar 2004
Re: Clearance under rear bench seat.
Doubt you are going to fit a box under your seat. You can always do what the jeep guys do....
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
I find a couple of small subwoofer,that where 15 x 10 x 3" tall with 8" woofer ,that I think will work.i was planning to install under the seat with a 5 channel amplifier,out of site,I just want a little bass.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 02-08-2015 at 02:27 PM. |
#5 | |
My Leatherman is 4". So I would say you have 3.5" depending on if you have carpet, rubber mat, or nothing. Mine appears to be 3.75" with rubber mat.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Thanks! 71SWB4x4 i appreciate that.i thank they will work.
I fit one under my seat in a '72 GMC Jimmy. I disassembled a sub I already had and put it in a custom box. Worked great, but if someone was sitting back there and you went over a large bump the seat would bottom out on the sub screen. I didn't have people riding back there very often so I never worried too much about it.
Yeah,I hope that's the case with me,thanks.
![]() Join Date: Nov 2007
I have a dual voice coil 8" sub I wanted to put under it and it would not fit. So make sure you measure the height of the speaker, and the 1/2 or 5/8 for wood, plus 1/8 or so of clearance, plus how much the speaker will stick out up top... or double wall top and recess it.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half ![]() 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
Ok,thanks.
