Old 02-06-2015, 07:18 AM   #1
Leroy-B1
grille help
I picked up an 81 chevy truck recently and really don't like the grille that's in it....I was wondering if I changed the grille to an 86 style grille do I need to change the radiator support also or are those the same.....the fenders and hood are the same as an 86 style just need to know what all I need to swap over to the newer style grille. ....any insight would be greatly appreciated
Leroy-B1 is offline   Reply With Quote
Old 02-06-2015, 08:35 AM   #2
J Knight
J Knight's Avatar
Re: grille help
If you have the single head light and want the stacked double head lights you need to change the rad sup. When you change from an 81-82 grille to an 83-87 the only thing you need to change is the lower filler panel between the bumper and grille.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 02-06-2015, 10:17 PM   #3
Leroy-B1
Re: grille help
Here's the current grille...want the stacked headlight grille like on a 84 to 87
Old 02-07-2015, 01:29 AM   #4
J Knight
J Knight's Avatar
Re: grille help
Well then you need:
a radiator core support with the stacked head lights
headlight/marker light harness (from firewall to lights)
83-87 lower filler panel(between grille and bumper)
85-87 grille
85-87 head light bezels
83-87 bumper without blinkers(85-87 grille has blinkers)
That should be it.
John
Old 02-07-2015, 09:03 AM   #5
Leroy-B1
Re: grille help
Thanks John
Old 02-07-2015, 02:44 PM   #6
Shifty One
Shifty One's Avatar
Re: grille help
Huh, I like the 81 design better than my single-headlight 87 set-up, and considered changing it out too...
