Old 02-06-2015, 10:32 PM   #1
hdff
hdff's Avatar
Trailing arms, don't need them but
Snooping around a salvage yard today came across a 72 short bed that was pretty caniblized up but still had the trailing arms on it, rear end was gone. I hate to see these trucks go to the masher with good parts on them. Is it worth my while to go back and see what they want for them and try to sell them or is it something that is better to get aftermarket and I would be stuck with them. They looked straight. The bed was gone so they were easy to see. I was looking for motor mounts and thought I had got lucky cause the motor was gone but the mounts were there, looked at the SPID and it had a 350 not a 400, so I was outta luck. So is there a need for used trailing arms?
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 02-06-2015, 10:43 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Trailing arms, don't need them but
I just bought a great original pair locally for $50. They're not worth too much.
EARNHARDT#3 is offline   Reply With Quote
Old 02-06-2015, 11:07 PM   #3
FirstOwner69
FirstOwner69's Avatar
I bought a pair for my 3/4 ton in Phoenix a couple years ago that looked almost new for $125 and was thrilled. I haven't seen any for sale for a 3/4 ton since. Most 1/2 ton trailing arms I've seen for sale range from $100 to $150. I think there will always be a market for good originals.
FirstOwner69 is offline   Reply With Quote
Old 02-06-2015, 11:24 PM   #4
leddzepp
Moderator
leddzepp's Avatar
If they were worth much they would have already been gone
If you need them or think you might in the future, I would pick them up. I would not buy them for resale, not worth it IMO.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-06-2015, 11:48 PM   #5
FirstOwner69
If you do get serious about buying them, be sure to check them over very carefully. Be sure no rust has formed between the 2 halves causing them to start spreading apart or cause perforation. Also, the U-bolts can be almost impossible to remove due to rust. I'd pass if either condition exists.
Old 02-07-2015, 12:41 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
It all depends on your location. It is almost impossible to find good ones in the Upper Midwest.... The rust belt as we like to call it.
LockDoc
Leon
Old 02-07-2015, 06:22 PM   #7
Fitz
Trailing arms on a '72????
Fitz is offline   Reply With Quote
Old 02-07-2015, 07:09 PM   #8
EARNHARDT#3
Coil springs=trailing arms.
